Trying to reconfig a PLL with the EMIF Calibration IP
debug via system console
Clocking and PLL User Guide: Agilex™ 5 FPGAs and SoCs
enabled dynamic config within IOPLL and included EMIT Calib.
writing to divide setting addresses -> changes are immediate
multiple pure phase shifts did not work (work randomly)
is there a bit to start the shift
with one design setting N - M - C worked but no multiple shifts
with an other design problems writing to 0x80 to reset pll after setting NMC, no replay
for new nmc setting 6.4.1 enable | 6.4.2 clear calib | 6.4.3 reconfig | 6.4.4 recal
for just phase shifting 6.4.1 read modify write 6.4.3 without 0x80
2.2.12 perform positive or negative phase shift - is there a bit for that?
Where did I go wrong?
Section 2.2.12 explains the PLL phase shift feature.
Phase shift behavior may depend on:
1- PLL locked status
2- Recalibration is triggered or not
3- EMIF IP is actively using the PLL or not
Regarding 0x80 reset is not responding- 0x80 is used to reset the PLL, but you need to make sure the PLL is not in used by EMIF or other IPs, and need to make sure PLL is not in locked status.
Try to follow below sequence :
1- Enable Reconfig
2- Clear calibration
3- Write new settings
4- Trigger Recalibration
regards,
Farabi
