6355 Discussions
Avalon MM FiFO csr_in and csr_out not working
matif
​Hi, I made the following setup. But my fifo write is working fine but fifo read is not working fine. Here is sample output
62
Please enter a number:
45
you entered the value :45
root@socfpga_cyclone5:~# ./customfifoloopback4write
46
you entered the value :46
47
you entered the value :47
48
you entered the value :48
49
you entered the value :49
60
you entered the value :60
61
you entered the value :61
62
Now when I read back data it is like just one number while I want to read out whole of the fifo
the output value from the fifo is 62
Here is c code for read and write
#define REG_BASE 0xFF200000 #define REG_SPAN 1024 void* virtual_base; volatile unsigned int * FIFO_write_ptr; unsigned int value; int main () { int fd = EXIT_FAILURE; fd=open("/dev/mem",(O_RDWR|O_SYNC)); if (fd < 0) { perror("open"); exit(EXIT_FAILURE); } virtual_base=mmap(NULL,REG_SPAN,(PROT_READ|PROT_WRITE),MAP_SHARED,fd,REG_BASE); if (virtual_base == MAP_FAILED) { perror("mmap"); } FIFO_write_ptr=(unsigned int *)(virtual_base+FIFO_0_IN_BASE); printf("Please enter a number: \n"); scanf("%i",&value); *FIFO_write_ptr=value; printf("you entered the value :%i\n",*FIFO_write_ptr); return 0; }#define REG_BASE 0xFF200000 #define REG_SPAN 1024 void* virtual_base; volatile unsigned int * FIFO_read_ptr; int i; int main () { int fd = EXIT_FAILURE; fd=open("/dev/mem",(O_RDWR|O_SYNC)); if (fd < 0) { perror("open"); exit(EXIT_FAILURE); } virtual_base=mmap(NULL,REG_SPAN,(PROT_READ|PROT_WRITE),MAP_SHARED,fd,REG_BASE); if (virtual_base == MAP_FAILED) { perror("mmap"); } FIFO_read_ptr=(unsigned int *)(virtual_base+FIFO_0_OUT_BASE); for(i=0;i<8;i++) { //reading data from the fifo printf("////////////////////////////\n"); printf("the output value from the fifo is %d\n",*FIFO_read_ptr); printf("/////////////////////////////\n"); } return 0; }
FawazJ_Altera
Thank you for using Intel forum.
May I know if this is a development kit or a custom board? if it is a development kit, may I know which board is it?
Thank you,
matif
@FJumaah​
Thank you for your reply and support. It is a developement kit. I have cyclone V arrow sockit board.
https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=167&No=816
matif
@FJumaah​
I am still waiting for any responce from you. Can you please guide me on this problem?
FawazJ_Altera
I am still working on your case,
Once I get a feedback I will let you know.
Thank you
