6459 Discussions
Avalon-MM master burst transfer
aamodini
I am transferring data from Nios (master) to the FPGA fabric (slave) through the Avalon-MM interface. How do I set the burstcount parameter on Nios and initiate a burst transfer?
I don't see any flag/API in system.h that will help set the burst count.
Labels (2)
ShengN_Intel
Check this document link https://faculty-web.msoe.edu/johnsontimoj/Common/FILES/n2cpu-nii5v1gen2.pdf (page 107, 108). Just need to enable the Add burstcount signal to instruction_master. Not need to set the burstcount parameter on Nios,  burst adapters will be inserted for the burst compatibility between Nios (master) to the FPGA fabric (slave).
Sheng
ShengN_Intel
May I know do you have any further concern or update on previous post?
Sheng
