6462 Discussions
Avalon fifo status pointers not working
matif
 I simply connected my Avalon memory fifo to hps.design.JPG​But the read and write status pointers are not working, they are stuck always at 0. any ideas? c code is also attached he
#include <stdio.h> #include <unistd.h> #include <stdlib.h> #include <stdint.h> #include <fcntl.h> #include <sys/mman.h> #include <sys/types.h> #include <sys/stat.h> #include "C:\altera\15.1\embedded\ip\altera\hps\altera_hps\hwlib\include\hwlib.h" #include "C:\altera\15.1\embedded\ip\altera\hps\altera_hps\hwlib\include\soc_cv_av\socal\socal.h" #include "C:\altera\15.1\embedded\ip\altera\hps\altera_hps\hwlib\include\soc_cv_av\socal\hps.h" #include "C:\altera\15.1\embedded\ip\altera\hps\altera_hps\hwlib\include\soc_cv_av\socal\alt_gpio.h" #include "D:\TestDesigns\customfifoloopback3\hps_0.h" //Main bus addresses #define FIFO_BASE 0xC0000000 #define FIFO_SPAN 0x00001000 //LW Addresses #define REG_BASE 0xFF200000 #define REG_SPAN 0x00200000 //initializing the pointers void* virtual_base; void* h2f_virtual_base; volatile unsigned int * FIFO_write_ptr; volatile unsigned int * FIFO_read_ptr; volatile unsigned int * FIFO_write_status_ptr; volatile unsigned int * FIFO_read_status_ptr; //unsigned int value; int data[8]; int i; //int FIFO_FULL; //int FIFO_EMPTY; //main functions int main () { int fd = EXIT_FAILURE; fd=open("/dev/mem",(O_RDWR|O_SYNC)); if (fd < 0) { perror("open"); exit(EXIT_FAILURE); } printf("fd is ok\n"); //accessing the virtual addresses of the fifo pointers virtual_base=mmap(NULL,REG_SPAN,(PROT_READ|PROT_WRITE),MAP_SHARED,fd,REG_BASE); h2f_virtual_base=mmap(NULL,FIFO_SPAN,(PROT_READ|PROT_WRITE),MAP_SHARED,fd,FIFO_BASE); printf("virtual base pointer to open device memory file is ok\n"); FIFO_write_status_ptr = (unsigned int *)(virtual_base+FIFO_0_IN_CSR_BASE); FIFO_read_status_ptr = (unsigned int *)(virtual_base+FIFO_0_OUT_CSR_BASE); FIFO_write_ptr=(unsigned int *)(h2f_virtual_base+FIFO_0_IN_BASE); FIFO_read_ptr= (unsigned int *)(h2f_virtual_base+FIFO_0_OUT_BASE); printf("fifo pointers are ok\n"); //entering data into the fifo for(i=0;i<8;i++) { data[i]=i+1; *FIFO_write_ptr=data[i]; printf("////////////////////////////\n"); printf("you entered the value %d\n",*FIFO_write_ptr); printf("fifo write status pointer is %d\n",*FIFO_write_status_ptr); printf("//////////////////////////////\n"); } printf("reading back the data\n"); for(i=0;i<8;i++) { //reading data from the fifo printf("////////////////////////////\n"); printf("the output value from the fifo is %d\n",*FIFO_read_ptr); printf("fifo read status pointer is %d\n",*FIFO_read_status_ptr); printf("/////////////////////////////\n"); } return 0; }
EBERLAZARE_I_Intel
According to our IP user guide, I am unsure if pointers value can be returned.
Have you look through the Avalon FIFO memory IP user guide?
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_embedded_ip.pdf#page=278
