6454 Discussions
BeMicroSDK debug core dump in Nios2 Software Build Tool for Eclipse
Tried to run the simplest of all tutorial program - HelloWorld in Nios2 Software Build Tool for Eclipse 10.1, the following error message is displayed not long after the debugger started:
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: OK
Reading System ID at address 0x080002A8: verified
Listening on port 1491 for connection from GDB: 59saccepted
assertion "m_state == state_debug" failed: file "nios2oci.cpp", line 158
/cygdrive/c/altera/10.1/nios2eds/bin/nios2-download: line 601: 9536 aborted (core dumped) nios2-gdb-server --cable 'usb-blaster on localhost [usb-0]' --device 1 --instance 0 --sidp 0x80002a8 --id 0x6060d7d5 --timestamp 1287701530 --tcpport auto --write-pid ./nios2-download.pid
After two weeks there is not single one program I can run successfully with BeMicroSDK. Any help will be much appreciated. Thank you in advance.
