I would like to know if it's possible for the IntelFpga team to create more Cadence PCB libraries for the Stratix 10 SX serie FPGA. At that time only the SX2100 is present and downloadable. In my company we plan to develop boards with small capacity and pin out (SX400 or SX650 for example). Would you mind doing that because as customer it will help us a lot. Best regards.
Hello
Welcome to INTEL forum. Pin-Out Files for Intel FPGA Devices you can refer here https://www.intel.com/content/www/us/en/programmable/support/literature/lit-dp.html?1 login to your Intel account.
My question is not about pin out file. It's about Cadence library. Intel give that files for most of the stratix component but in the SX serie there's only one file (the SX2100).
It will help a lot and also avoid possible mistake during designing step if all that lacking library where given by the Intel support.
Hi sir
The Cadence library will be update accordingly from time.
