6472 Discussions
Configuring the FPGA Fabric from Linux
lanjw
I follow the 6.2 chapter of "ug-agilex-soc-boot-683389-766161.pdf" file to configure the fpga fabric from linux. But the error is occurred:
I don't know what happened. Please help!
The following message should be told to you:
1. Quartus Prime version: 22.4;
2. Linux kernel version: 5.15.70;
3. Soc fpga type: Agilex7;
4. Match to below requirements:
aikeu
Hi lanjw,
May I know are you working with a gsrd?
You can try to get the gsrd first to boot with prebuilt binaries in order to check without issue and also as a reference to troubleshoot any issue when building your own images.
https://www.rocketboards.org/foswiki/Documentation/AgilexSoCGSRD#Booting_Linux_Using_Precompiled_Binaries
Then by following the building bootloader document to modify/build part of the binaries to test out for any issue comparing with the prebuilt binaries.
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderAgilex7
Aik Eu
aikeu
Hi lanjw,
May I know any feedback from the previous comment?
Aik Eu
aikeu
Hi lanjw,
I will close this thread if no further feedback.
Aik Eu
aikeu
Hi lanjw,
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Aik Eu
