6473 Discussions
Critical Warning while generating SOF file for CXLtype 3 example design
mjuneja2007
I am getting below Critical Warning while generating SOF file for the example design of CXL IP type 3 with DDR4 controller for Agilex-7 board (DK-DEV-AGI027-RA).
"Message ID :- 24567
The design is using an internal oscillator along with transceivers, EMIF, MIPI and PHY Lite interfaces."
Can you please suggest me what could be the possible reason for the same ?
Or Can I suppress the message with this ID ?
Thanks & regards
Madhur Juneja
FvM
sounds like wrong design setup. Development board is using 125 MHz external oscillator as configuration clock, apparently you have selected internal oscillator as configuration clock in device options.
FvM
paveetirrasrie_Intel
Hello Madhur Juneja,
Good day to you.
Does clarification provided by our contributor helps?
Pavee
I’m glad that your question has been addressed, I now transition this thread to community support.
If you have a new question, feel free to open a new thread to get the support from Altera experts.
Otherwise, the community users will continue to help you on this thread.
Thank you.
