6478 Discussions
Cyclone 10 GX dev kit, which signal can I use to reset a NIOS?
Oliver_I_Sedlacek
New Contributor III
I've had a look at the Cyclone 10 GX dev kit user manual and schematics but it's not clear if the board provides a signal to the C10 that will drive the NIOS platform reset input correctly. Any suggestions?
I suppose I could code up a pulse generator that runs after configuration but I was hoping for something official.
Edit - found pin AC12 has a likely sounding assignment of fpga_resetn which seems to come from a MAX10. Any clues as to what the MAX10 does with it?
FvM
you find a brief description in user manual. Check S13 function.
Oliver_I_Sedlacek
New Contributor III
I found that, but that's a manual reset. How to I give my NIOS a post configuration automatic 'power on' style reset?
wwanalim_intel
Thank you for reaching us.
You can enable Include cpu_resetrequest, and use a PIO IP as input into cpu_resetrequest.
Or, with the connection below made, use the debug module to reset the core only.
If the same signal is connected to other IP's reset, you can extend to full system reset.
You also can refer below link about this.
https://www.intel.com/content/www/us/en/docs/programmable/683836/current/reset-and-debug-signals.html
wwanalim_intel
I am sorry for the picture above. Below I reattached the picture.
Oliver_I_Sedlacek
New Contributor III
This seems to be a way to add more reset (sink) inputs. I'm looking for a reset source to drive the reset input after FPGA configuration.
wwanalim_intel
I would suggest for you to connect a PIO IP to another push-button and feed it into the cpu_resetrequest.
Oliver_I_Sedlacek
New Contributor III
That's not what I'm after. A manual reset isn't an alternative to a configuration completion reset.
BTW it's taken me an hour to get to the point of replying to this thread because the forum software is so flaky it wouldn't put up this box for me to reply. I've tried several browsers and several login in cycles. For a billion dollar corporation this is very, very poor.
wwanalim_intel
It is unfortunate from our side that our suggestion is different from what you prefer. Can you elaborate more about the manual reset? We quite confused on that part.
wwanalim_intel
Since you cannot replied to this thread, lets continue on the other thread that I already replied.
https://community.intel.com/t5/Nios-V-II-Embedded-Design-Suite/Debugger-wont-connect-to-NIOS-II-hello-world-on-Cyclone-GX/m-p/1540301#M52293
Thank you.
wwanalim_intel
Do you have any updates to share about this issue?
wwanalim_intel
I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
KennyTan_Altera
Test
