6472 Discussions
Cyclone IV GX Development Kit powered through PCIe
Contributeur émérite II
1 735 Visites
I would like to connect "Cyclone IV GX Development Board" to a motherboard through PCIe port, but the motherboard can provide only 10W.
According the Reference Manual of Development Board, it is not recommended to use from both supplies at the same time (power connector + PCIe).
Is 10W enough to power the board for a standard application (e.g. Altera's PCI Express Demo)?
Is it possible to power the board from both supllies without damages to the board and motherboard?
0 Compliments
2 Réponses
623 Visites
Anyone?
Would It be possible to power the board from both supllies without damages to the board and motherboard?
0 Compliments
623 Visites
--- Quote Start ---
--- Quote End ---
Here is that phrase from "Cyclone IV GX FPGA Development Board Reference Manual":
"the board’s power can be sourced entirely from the pcie edge connector when
installed into a pc motherboard. turn the power switch (sw3) to the on position
when you install the board into a pc motherboard. although the board can also be
powered by a laptop power supply for use on a lab bench, it is not recommended to
use from both supplies at the same time. ideal diode power sharing devices have been
designed into this board to prevent damages or back-current from one supply to the
other."
But "Cyclone IV GX FPGA Development Kit User Guide" says:
3. connect the dc adapter (16 v, 60 w) to the dc power jack (j5) on the fpga board
and plug the cord into a power outlet.
4. set the power switch (sw3) to the on position. when power is supplied to the
board, a blue led (d11) illuminates indicating that the board has power.
I don`t understand:
1). How to make that the board’s power is sourced entirely from the PCIe edge connector +12V_PCIe? What is the correct position of the SW3 for that?
2). What laptop power supply is this Reference Manual talking about?
Is it a DC adapter (16 V, 60 W) from "Cyclone IV GX Development Kit" that has to be connected to the DC power jack (J5) on the FPGA board?
Here is the corresponding screenshot from "Cyclone IV GX Development Kit" schematic:
https://www.alteraforum.com/forum/attachment.php?attachmentid=7693
0 Compliments
Répondre
