6472 Discussions
Cyclone V GX Starter Kit SD Card
Hi, I received my Cyclone V GX Starter Kit with SD Card support, ran the C5G_SD_DEMO Demonstration only
programming the sof file (Quartus II 13.0 web edition), and ran using Nios II 13.0 Software Build Tools for Eclipse, everything worked ok.
bu when trying to compile through Quartus II enviroment (web edition) generating "C5G_SD_DEMO_time_limited.sof"
and then using Nios II IDE again, the elf is programmed well and Verification is OK also
but nothing is working, seems like the CPU is stuck
even debug not breaks at any point. what could be the problem?
