6478 Discussions
Cyclone V SoC Development Kit License question
CAlex
New Contributor II
I want to buy the Cyclone V SoC Development Kit with SOC EDS,
but I don't know whether it contains all the development environment for free(basically ARM DS license).
What's the difference between ARM DS and ARM DS-5?
Does this support the HPS RTOS?
Also does this kit support the Terasic optical fiber cable module?
Thank you.
Reguards.
CAlex
New Contributor II
Another thing is that if I bought that board does it support DS-5(contain previous version SOC EDS DS-5 license?)
JingyangTeh_Altera
Hi Alex
Arm-DS and Arm-DS 5 is the same thing Arm-DS 5 is the version of the tool.
The Cyclone V SOC Development Kit does not contain the Arm-DS licensing.
https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/cyclone/v-sx.html
Jingyang, Teh
CAlex
New Contributor II
I applied ARM DS for 30 day free license but when I want to debug I got the following error:
I used the SOC EDS to lanch the armds_ide,
I set the debug config as followed:
intel->cyclone V soc->dual core->cpu_0
I chose USB-Blast and auto HZ, USB 1 was found.
The tortural Hardware Library (HWLibs) | Documentation | RocketBoards.org
used the Dstream but my Dstream selection didn't found any device.
How can I fix that?
Reguards.
JingyangTeh_Altera
Hi Alex
Could you try adding your license file path into windows environmental variable?
ARMLMD_LICENSE_FILE
USB Blaster is fine too, you do not need to change it to Dstream.
Jingyang, Teh
JingyangTeh_Altera
Hi Alex
Any update on this case?
Do you need some more time for this case?
Jingyang, Teh
CAlex
New Contributor II
I set the ARMLMD_LICENSE_FILE as you suggested,
It didn't work for me.
It searched the AppData/Roaming/Arm/ARM DS 2022.2/license.dat
But there was no such file.
I don't know what to do to fix it.
Reguards.
JingyangTeh_Altera
Hi Alex
Could you try adding the path to the license in the license manager once again.
Help >> License Manager
It is weird, the license is working fine on my end.
Jingyang, Teh
CAlex
New Contributor II
the weird thing happened to me too.
The license worked today when I restarted the armds.
Thank you for your help.
Please do whatever you need to this thread.
JingyangTeh_Altera
Hi
Since this thread been resolve, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
