- Contrassegnare come Nuovo
- Preferito
- Iscriversi
- Disattiva notifiche
- Iscriversi a feed RSS
- Evidenziare
- Stampare
- Segnalare contenuto inappropriato
I'm designing a very compact design with a 5CEFA4 Cyclone V FPGA and a single DDR3 chip.
Following the Micron and Intel guidelines, I chose to not use VTT termination and to use only a simple resistor divider for Vref generation. I've seen that in other working designs, so I'm pretty confident all will work as expected.
To effectively choose the divider resistance value I need to know the max leakage current of Vref pin of the FPGA...anyone knows where I can find it?
On the Cyclone V Datasheet I see only the I/O pins leakage current, which is quite high, +-30uA, compared to the +-1uA of the DDR3 chip.
Link copiato
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi ,
The maximum leakage current for the IO pins , is 30uA,
Page no: 13
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-v/cv_51002.pdf
The above value is the characterized value from Intel FPGA .
- Preferito
- Iscriversi
- Evidenziare
- Stampare
so you're telling me thah Vref pins are considered as I/O pins?
I thought they're special pins with different characteristics.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi Zak,
Kindly find the KDB for your reference, as I mentioned the leakage is only characterized for the IO, as per me the same can be considered for VREF . Kindly find the KDB for your reference.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd11122003_7976.html?wapkw=vref%20leakage
- Contrassegnare la discussione come nuova
- Contrassegnare la discussione come letta
- Sposta questo Discussione per l'utente corrente
- Preferito
- Iscriversi
- Pagina in versione di stampa
