6472 讨论
DDR4 IC interface with Intel FPGA Family
VivekV
初学者
1,202 次查看
Is there any reference board for FPGA SoC (AGILEX series), with DDR4 SD RAM not SODIMM but direct IC.
0 项奖励
6 回复数
AdzimZM_Intel
员工
1,175 次查看
Hi VivekV,
Thank you for submitting your question in Intel Community.
I'm Adzim from Penang Global Application Engineer will assist you in this thread.
From my understanding, the memory IC that you are referring to is a component type memory or an on-board memory.
For Agilex series, I can suggest the Agilex F-Series Transceiver-SoC Dev Kit: https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/agilex/f-series-transceiver/si-agf014.html
The Dev Kit has a DDR4 memory component with 8GB x72bit.
For any further details, you can refer directly to Intel Distributor that available in your region.
Link: https://marketplace.intel.com/s/pmp-partner-program/a723b0000008PICAA2/distributor?language=en_US
Adzim
0 项奖励
VivekV
初学者
1,171 次查看
Thank you,
The Dev Kit you shared is Agilex F- Series Transceiver -SoC (P- Tile and E- Tile),
what I want is in  Agilex F- Series Transceiver -SoC (F- Tile), Is there any reference board available for our design.
Vivek V
0 项奖励
AdzimZM_Intel
员工
1,151 次查看
Hi Vivek V,
"what I want is in Agilex F- Series Transceiver -SoC (F- Tile), Is there any reference board available for our design."
Unfortunately the development kit that used Agilex F - Series Transceiver - SoC (F-tile) is not available.
But you can reach out to Intel Distributer to address your request.
Link:https://marketplace.intel.com/s/pmp-partner-program/a723b0000008PICAA2/distributor?language=en_US
Adzim
0 项奖励
VivekV
初学者
1,138 次查看
If the board design available, just need to know how are pins of DDR4 SDRAM component assigned to Agilex Soc F-series F- tile Pins
Vivek V
0 项奖励
AdzimZM_Intel
员工
1,098 次查看
Hi Vivek V,
Sorry we don't have have the board design for that device with memory component that you are looking for.
You refer to device design guideline when creating the board layout.
LINK: https://www.intel.com/content/www/us/en/docs/programmable/683634/21-2/introduction-to-the-device-design-guidelines-78756.html
Adzim
0 项奖励
AdzimZM_Intel
员工
1,075 次查看
As we do not receive any response from you on the previous reply that we have provided, I now transition this thread to community support. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
0 项奖励
回复
