I'm new to Quartus and Nios, and I've been trying to get the DE2-115 web server example (RGMII-ENET0) running with no luck. I followed the instructions in the user manual trying the bat file first.
Using Nios 10.1 I:
- Programmed the flash with the file DE2_115_Web_Server\DE2_115_WEB_SERVER_RGMII_ENET0\software\web_server_0_syslib\ro_zipfs.zip in Nios II Flash Programmer with the DE2_115_Web_Server\DE2_115_WEB_SERVER_RGMII_ENET0\DE2_115_SOPC.sopcinfo (attached is a screen shot of the programmer commands).
- Ran batch file: DE2_115_Web_Server\DE2_115_WEB_SERVER_RGMII_ENET0\demo_batch\web_server.bat
Console Output:
C:\Altera\de2\DE2_115_Web_Server\DE2_115_WEB_SERVER_RGMII_ENET0\demo_batch>
C:\Al tera\10.1\quartus
\\bin\\quartus_pgm.exe -m jtag -c USB-Blaster[USB-0] -o "p;DE2_
115_WEB_SERVER.sof"
Info: *******************************************************************
Info: Running Quartus II Programmer
Info: Version 10.1 Build 153 11/29/2010 SJ Full Version
Info: Copyright (C) 1991-2010 Altera Corporation. All rights reserved.
Info: Your use of Altera Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Altera Program License
Info: Subscription Agreement, Altera MegaCore Function License
Info: Agreement, or other applicable license agreement, including,
Info: without limitation, that your use is for the sole purpose of
Info: programming logic devices manufactured by Altera and sold by
Info: Altera or its authorized distributors. Please refer to the
Info: applicable agreement for further details.
Info: Processing started: Mon Dec 27 10:27:18 2010
Info: Command: quartus_pgm -m jtag -c USB-Blaster[USB-0] -o p;DE2_115_WEB_SERVER
.sof
Info: Using INI file C:/Documents and Settings/dreesewm/quartus.ini
Info: Using programming cable "USB-Blaster [USB-0]"
Info: Using programming file DE2_115_WEB_SERVER.sof with checksum 0x00E08E03 for
device EP4CE115F29@1
Info: Started Programmer operation at Mon Dec 27 10:27:19 2010
Info: Configuring device index 1
Info: Device 1 contains JTAG ID code 0x020F70DD
Info: Configuration succeeded -- 1 device(s) configured
Info: Successfully performed operation(s)
Info: Ended Programmer operation at Mon Dec 27 10:27:26 2010
Info: Quartus II Programmer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 103 megabytes
Info: Processing ended: Mon Dec 27 10:27:26 2010
Info: Elapsed time: 00:00:08
Info: Total CPU time (on all processors): 00:00:01
Altera Nios2 Command Shell [GCC 3]
Version 10.1, Built Tue Nov 30 02:10:00 PST 2010
Welcome to the Nios II Embedded Design Suite
Version 9.1, Built Thu Mar 25 01:25:52 PDT 2010
Example designs can be found in
/cygdrive/c/altera/91/nios2eds/examples
(You may add a startup script: c:/altera/91/nios2eds/user.bashrc)
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
Initializing CPU cache (if present)
OK
Downloaded 345KB in 5.9s (58.4KB/s)
Verified OK
Starting processor at address 0x000001D0
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
prep_tse_mac 0
Your Ethernet MAC address is 00:05:67:f0:13:53
prepped 1 interface, initializing...
[tse_mac_init]
INFO : TSE MAC 0 found at address 0x0b442000
INFO : PHY Marvell 88E1111 found at PHY address 0x10 of MAC Group[0]
INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0]
INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link...
INFO : PHY[0.0] - Auto-Negotiation PASSED
INFO : PHY[0.0] - Checking link...
INFO : PHY[0.0] - Link established
INFO : PHY[0.0] - Speed = 1000, Duplex = Full
OK, x=0, CMD_CONFIG=0x00000000
MAC post-initialization: CMD_CONFIG=0x0400020b
[tse_sgdma_read_init] RX descriptor chain desc (1 depth) created
mctest init called
IP address of et1 : 192.168.0.171
Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
Acquired IP address via DHCP client for interface: et1
IP address : 117.252.214.160
Subnet Mask: 255.255.255.0
Gateway : 192.168.0.1
Created "web server" task (Prio: 4)
Web Server starting up
Fetching file: /mnt/rozipfs/index.html.
Can't open the 404 File Not Found error page.
Have you programmed the filing system into flash?
[http_handle_receive] Error preparing response
I tried changing the base address to 0x00000000 due to some comments in the readme, but I still have the same error.
I also tried building the example from the CD (v1.0.4) but the software doesn't do anything when you select Build All. Building from scratch with the Web Server Template gives the error:
Description Resource Path Location Type
make: *** [obj/alt_error_handler.o] Error 1 test_web_server_one line 0 C/C++ Problem
Any help on this would be appreciated.
