Hi~
I bought a DE2 Board to study NIOS II. When I compiled some demonstration projects, I had following warning. "Info: SRAM Object File C:/z.temp/DE2_System_v1.6/DE2_System_v1.6/DE2_demonstrations/DE2_NIOS_DEVICE_LED/HW/DE2_NIOS_DEVICE_LED_time_limited.sof contains time-limited megafunction that supports OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0x00A2" So I can't make pof file. How can I solve problem? Another sample project including NIOS II works fine. TIA,Link Copied
--- Quote Start --- Hi~ I bought a DE2 Board to study NIOS II. When I compiled some demonstration projects, I had following warning. "Info: SRAM Object File C:/z.temp/DE2_System_v1.6/DE2_System_v1.6/DE2_demonstrations/DE2_NIOS_DEVICE_LED/HW/DE2_NIOS_DEVICE_LED_time_limited.sof contains time-limited megafunction that supports OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0x00A2" So I can't make pof file. How can I solve problem? Another sample project including NIOS II works fine. TIA, --- Quote End --- your design contains a Megafunction which is not fully support by your Quartus license. I assume that you use the Web Edition of the Altera tools. You can solve the problem only by upgrading your tools to the full versions. Kind regards GPK
Topic Options
