I''m pretty new to VHDL and I'm trying to get the DE0-NANO to poll inputs 0-3 and send the data to 4 12 bit registers. I have tried it a numebr of ways but it either didn't work or had some sort of interference. Can anyone help? Here is my code that was based on the DE0-NANO example. module ADC_CTRL ( // iCLK, iCLK_n, oCH0, oCH1, oCH2, oCH3, oDIN, oCS_n, oSCLK, oCH, iDOUT ); input iCLK; input iCLK_n; output [11:0] oCH0; output [11:0] oCH1; output [11:0] oCH2; output [11:0] oCH3; output [1:0] oCH; output oDIN; output oCS_n; output oSCLK; input iDOUT; reg data =0; // serial address data out reg go_en=1; wire [1:0] ch_sel= 2'b10; reg sclk; reg [3:0] cont; reg [3:0] m_cont; reg [11:0] adc_data; reg [11:0] ch0; reg [11:0] ch1; reg [11:0] ch2; reg [11:0] ch3; assign oCS_n = ~go_en; assign oSCLK = (go_en)? iCLK:1; assign oDIN = data; assign oCH0 = ch0; assign oCH1 = ch1; assign oCH2 = ch2; assign oCH3 = ch3; assign oCH = ch_sel; // always@(posedge iGO ) // begin // if(!iRST) // go_en <= 0; // else // begin // if(iGO) // go_en <= 1; // end //end always@(posedge iCLK ) //begin // if(!go_en) // cont <= 0; // else begin if(iCLK) cont <= cont + 1'b1; end //end always@(posedge iCLK_n) begin if(iCLK_n) m_cont <= cont; end always@(posedge iCLK_n ) //begin // if(!go_en) // data <= 0; // else begin if(iCLK_n) begin if (cont == 2) data <= 0; else if (cont == 3) data <= ch_sel[1]; else if (cont == 4) data <= ch_sel[0]; else data <= 0; end end //end always@(posedge iCLK) begin if(!go_en) begin // will never get run adc_data <= 0; ch0 <= 12'h000; ch1 <= 12'h000; ch2 <= 12'h000; ch3 <= 12'h000; end else begin if(iCLK) begin if (m_cont == 4) adc_data[11] <= iDOUT; else if (m_cont == 5) adc_data[10] <= iDOUT; else if (m_cont == 6) adc_data[9] <= iDOUT; else if (m_cont == 7) adc_data[8] <= iDOUT; else if (m_cont == 8) adc_data[7] <= iDOUT; else if (m_cont == 9) adc_data[6] <= iDOUT; else if (m_cont == 10) adc_data[5] <= iDOUT; else if (m_cont == 11) adc_data[4] <= iDOUT; else if (m_cont == 12) adc_data[3] <= iDOUT; else if (m_cont == 13) adc_data[2] <= iDOUT; else if (m_cont == 14) adc_data[1] <= iDOUT; else if (m_cont == 15) adc_data[0] <= iDOUT; else if (m_cont == 1) begin case (ch_sel) 2'b00 : ch0 <= adc_data; 2'b01 : ch1 <= adc_data; 2'b10 : ch2 <= adc_data; 2'b11 : ch3 <= adc_data; endcase // ch_sel = ch_sel + 2'b01; end end end end endmoduleLink Copied
Writing testbench to simulate your design to identify which part having the issue.
