6468 Discussions
Diff Clk pins used as I/O on a Cyclone 10 LP
yes2
I'm aware that DIFFCLK pins can be used as general I/O, however can a single ended clock be used on one of the pins, with general I/O used on its differential pair?
I am using a Cyclone 10 LP if that makes any difference.
Cheers!
yes2
I forgot to also mention these are CLK#/DIFFCLK_# input pins. Not output or I/O.
lixy
Hi yes2,
No.
The (p) and (n) pins of a differential pair is fix. For example, in Quartus, when you set the (p)'s pin location of a differential signal, the n-terminal will be set accordingly.
You can also see this from the device Pin Information document. Example as below.
Xiaoyan
FvM
Hi, previous post dosn't seem to answer your specific question.
I unerstand that you want to use CLK pins with single ended clock signal. In this case, p and n pin of a pin pair are independent. You can e.g. use CLK0 (DIFFCLK_0p) as clock input and CLK1 (DIFFCLK_0n) as user input signal.
Generally, refer to current pin connection guideline https://www.intel.com/content/www/us/en/docs/programmable/683137/current.html
and test the chosen pin configuration in Quartus.
lixy
Since you didn't give further comments, I wonder if you have got the answer for the question?
If you still have more questions related, please feel free to ask here!
If no, we will close this case. Thanks!
XY
