6468 Discussions
Driver(A10SA4) to program Arria 10 PAC
druva1
I have an Arria 10 PAC (programmable acceleration card). I want to use the programmer of Quartus Standard 19.1 to load a simple Verilog code that I have.
When I connected the board it shows A10SA4[USB-1] in the Device manager. I have not been able to find this driver to program this board. If I could get it I would appreciate it.
Cheers
druva1
I still have that error in the device manager but I can program the board using Quartus. Not sure how is this possible. So it kinda got fixed at the moment.
druva1
I think  I should add the image of what I am referring to.
EricMunYew_C_Intel
you can find it in intelFPGA_pro\19.2\quartus\drivers\usb-blaster-ii
druva1
Thank you for your response but it does not work. Windows says it cannot find the A10SA4 driver.
I should mention that I had previously installed the usb-blaster ii as shown in the attached picture.
cheers
druva1
EricMunYew_C_Intel
The usb blaster ii will allow you to program the Arria 10 PAC card.
