- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
We are trying to enable enable Ethernet stack on the Linux OS installed on HPS of "Agilex™ 5 FPGA E-Series 065B Premium Development Kit". The dev kit comes with two QSFPs and two SFP+ physical ports.
Wondering if anyone has been able to successfully connect Linux OS Ethernet driver to any of the QSFP or SFP+ port? If yes, can you please point to any documentation or user-guide or provide hints.
We have been exploring possibly connecting via the TSE soft-IP, but don't know how to go about it.
Here is our desired configuration:
Our Linux User Application <--> Linux OS running on ARM-core HPS <--> Ethernet Driver (stack) <---> Ethernet TSE IP <---> Agilex 5 FPGA Fabric <----> Ethernet PHY <---> SFP+ or QSFP.
We are trying to understand: How should we implement this Ethernet connectivity? Is there a specific driver that we need to use on the OS side? How should we configure the TSE?, etc.
We want to use soft-IP because we want to enable at least two interfaces (SFP+ or QSFP) simultaneously.
FYI: The FPGA part number on our board:
The FPGA part number on our Premium board is: A5ED065BB32AE6SR0
Thank you in advance for any guidance or pointers.
Sincerely,
RS
Lien copié
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
