Dear all,
I am also using stratix II EP2S60 I use Quartus and Nios version 6.0 After finish compiling all, I have a problem with Nios when I download . The error appear as following: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x021208B8: verified Initializing CPU cache (if present) OK Downloading 01000020 ( 0%) Downloaded 62KB in 0.9s (68.8KB/s) Verifying 01000020 ( 0%) Verify failed between address 0x1000020 and 0x100F457 Leaving target processor paused another thing I don't understand is if I download other programs ( for example: the program in "C:\altera\kits\nios2_60\examples\vhdl\niosII_stra tixII_2s60\standard" ) It's ok. But my own program has that trouble. Please help me. I tried so much but can't figure it out. Thanks alot . Best regards, Edit/Delete MessageLink Copied
