- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Inconsistent Ethernet Functionality on Ethernet MPN: 88E1111-B2-NDC2I000 with Cyclone V device 5CSEMA5U23I7N.
We are experiencing significant inconsistency in Ethernet working, leading to unreliable data communication.
We have verified Voltages and cable assembly .
Given the critical nature of stable Ethernet connectivity, we urgently request your expertise and support to diagnose the root cause of this inconsistency and provide a lasting solution. Could you please outline the diagnostic steps you recommend or provide a plan for further investigation?.
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
"Inconsistent Ethernet Functionality" is a rather loose description. I'd start with state-of-the-art diagnosis tools like Wireshark to determine what's exactly failing.
I'd expect a software problem in the first place. Respectively used Ethernet IP and software stack should be considered. As far as I'm aware of, there are also diagnosis options inside Ethernet stack, starting with simple things like error counters etc.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello Arun,
Kindly describe what's the error that you're observing at your end in detail so that we can debug further on this.
Pavee
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello Arun,
We didn't hear from you since last update. If you have a new question, feel free to open a new thread to get the support from Altera experts.
Otherwise, the community users will continue to help you on this thread.
Pavee
