6478 Discussions
FA request - EP2C5F256I8N Field return
Kulwiwat
We have got customer field return and suspected EP2C5F256I8N short circuit.
So, we would like to return this suspect part to Intel for full failure analysis.  total 1 pc defect.
The resistance check on good units around 4.3 K Ohm while on the NG is  219 Ohm.
Zawani_M_Intel
Hi Kulwiwat,
Can you tell me a story of this failure or you can provide :
1.What is the failure symptom? Please elaborate the failure symptom in detail.
2. When did the failure happen? How did you discover the failure?
3. How did you determine the failure? Please elaborate the procedures.
4. Does the failure unit ever working before failure?
5. Suspected pins
6. Failure Rate. Failed vs Tested
7. End Customer
Wani
