6474 Discussions
FFT IP option creates .qsys file instead of .qip
Sushmita
I am using quartus 18.1 version. i want to use FFT IP.
When I open the IP from IP catalog, i can see a platform designer option for FFT IP. i want to use the IP inside my design as a .qip file. Is there a option for that?
Can I use FFT IP inside my RTL as an instance?
SyafieqS
Hi Susmita,
You can get the FFT qip after you generate the HDL in PD. Yes, you can use it inside your RTL as instance.
