5952 Discussions
FPGA Current consumption
Mohammed_Asif_S
i am using 5M570ZT100C5N, i need to calculate the current consumption of this device, i am powering this device VCCINT 1.8V and VCCIO by 3.3V.
How to calculate the power consumption of this device ?
AndrewG_Intel
Hello @Mohammed_Asif_S
Based on the part number that you provided, we noticed this is regarding the MAX® V CPLD Development Kit. We have a forum for those specific products and questions so we are moving it to the FPGA, SoC, And CPLD Boards And Kits Forum so it can get answered more quickly.
Andrew G.
AminT_Intel
Hello Mohammed,
Thank you for using Intel® MAX® V FPGA.
You can calculate the power consumption of this device by using Early Power Estimator (EPE). You can find EPE of your device from this link
You can see the current consumption of each rail change as the I/O count for each module changes in under I/O tab. To view the current consumption per module, refer to the values in the "ICCIO" column in the EPE.
Hope this answer helps in your next design. Stay safe!
Thank you
AminT_Intel
I apologize that I put the wrong link. The correct link is here. Select your device and download it's EPE.
