6472 Discussions
FPGA Opencl caching for CPU access to shared memory through ACP port
jackgreen
I am doing a project on CycloneV soc which involves transferring large amount of data from memory to FPGA. As DMA needs to work with physically contiguous memory, I copied data to the share memory first (allocated by clEnqueueMapBuffer) and then FPGA consumes the data accordingly.
The problem I am having now is that moving data to the shared memory in user space is very time-consuming. I think it is due to the fact that Intel OpenCL library disables the caching for cpu access to the shared memory (as shown in the following pic). I can understand that it's hard to manage cache coherence in this case but it is not impossible to achieve!
As the Intel OpenCL library is not open-source, it seems hard for us to do any changes and enable the cache. Can anyone tell me a way around this problem, plz?
EBERLAZARE_I_Intel
Instead of trying to enable the CPU cache which does not guarantee the performance of moving your data, you could try and check the best practices in the optimizing memory access section to possibly improve the performance:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl-best-practices-guide.pdf#page=150
jackgreen
Thanks for your reply!
However, I am satisfied with the performance of the kernel right now. And I really want to optimize the process where data is transferred to and from the shared memory. It costs much more time than the kernel running.
EBERLAZARE_I_Intel
Yes, have you tried apply the best practice guide previously? It is recommended that you do so. I hope that helps.
