6472 Discussions
Help with something on board
antonto
I have the MAX10 DE10-Lite, could someone explain me what exactly this does? I have marked it with yellow on the picure.
Sorry if the question is a bit odd  im kinda new to this and i was wondering what could u do with it. Like is the 5v as input or output? what could u do with it etc.
Thank you for your time.
_AK6DN_
Valued Contributor II
That is JP6. It is a 2pin header that allows you to supply 5V power to the board thru it. It is input to the board only.
The connector is diode-or'ed with the USB 5V power input so that power to the board can come from either source (or both).
Most users will just supply 5V power to the board thru the USB cable which also supports the USB Blaster programming functionality.
_AK6DN_
antonto
Thank you for your explanation and your time!
cfkd
Hi
You can also use this resourceful web page to learn more about what you can do with DE10-lite:
https://fpgacademy.org/
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you,
Chee
