6458 Discussions
Hi, I am using max 10 10m08sae144c8g board. For the initial values of the internal registers, are they still meaningful when power up the board, or they just keep the initial value only for simulation?
YRong
JohnT_Intel
Yes, if you define it in your design. If not I would recommend that you reset your design in order to get the initial value.
YRong
Hi, Thanks for your answer. I still have 2 questions. 1. By vhdl programming, is "signal cnt_comm_cycle : integer range 0 to 6 := 0;" meaning that I have defined the initial value? If that, can I set the initial value to 1 ( "signal cnt_comm_cycle : integer range 0 to 6 := 1;" )? Because I find that sometimes when I set an initial value not equaling 0, then the total code is wrong (RTL simulation is fine, but downloading to the board is not working correctly). Then I just change the defined initial value to 0, and use a reset to reset the signal to 1, and it seems to work. Is there some settings in Quartus to make sure that setting initial value is valid? 2. And for the state machine initial value, for the following two lines, type t_SM is (IDLE, PRE_STRB, PRE_START, START, IN_FRAME, PRE_STOP, STOP); signal state : t_SM := IDLE; Is it meaning that the initial state will be IDLE after the board is powered up? Thanks a lot, Yu
YRong
a_x_h_75
New Contributor III
There is no setting in Quartus to ensure these initial values are observed. The power up value of the registers is determined by the FPGA technology/family.
If you want to guarantee a particular value in a register prior to your logic running you will have to use a reset signal.
Cheers,
Alex
