hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
6326 Discussions
How to control max v of arria10
aaronyen
I used Arria10 GX FPGA Development Kit.
For some reason the power supply was unstable. Can I configure the MAX V power settings to control the voltage limit?
Could you give me some solution?
thanks
Fakhrul
Hi aaronyen,
You may check the sub-topic: 10.7. Power Sequencing Considerations for Arria 10 Devices in this document: https://cdrdv2.intel.com/v1/dl/getContent/666662?fileName=a10_handbook-683461-666662.pdf
Also please check whether all power rails are within the required spec. Refer:
Intel® Arria® 10 Device Datasheet
Fakhrul
