6472 Discussions
How to download jic file to C10 lp eval-kit flash memory
LFu00
I have C10 lp eval-kit Rev A2 (128 Mb EPCQ-A). I use Quartus Prime Lite 18.1. This free edition Quartus seems not support Board Test System. I want to generate jic file for my own design and down load jic file to flash memory. Since this eval-kit has MAX 10, which I don't want to mess up (it is not user programmable), I am not sure if I should add this device to chain description file cdf window. If I don't add MAX 10, then I will get error saying "209031 Device chain in Chain Description File does not match physical device chain -- expected 1 device(s) but found 2 device(s). " and "209012 Operation failed". I don't know how to add MAX 10 to cdf window properly. If I add MAX 10 to chain, the error is "209012 Operation failed". What is the proper way to configure this chain? Thanks!
LFu00
AnandRaj_S_Intel
Hi Lisa,
Click on Autodetect, right-click & select change file and select .jic and click start.
Regarding chain description file, it should be somthing like
Device PartName(10CL025Y) Path("project Directory /output_files/") File("output_file.jic") MfrSpec(OpMask(1) SEC_Device(EPCQ128) Child_OpMask(1 1));
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand
LFu00
Hi Anand,
Thank you for help!
I have followed your instruction to setup cdf window. I still get error saying "209012 Operation failed". This is same as the error I got before. I have attached a screen shot here. What else I probably did wrong?
Lisa
AnandRaj_S_Intel
Hi Lisa,
Okay,
You have to change the switch (SW.4=bypass) state and try the steps mentioned in the previous post.
Anand
LFu00
Hi Anand,
Thank you for help! You are correct. I forgot to set sw1.4 to "ON" position. After that I can download jic file to flash without problem.
Lisa
