6472 Discussions
Intel Arria 10 SoC - HPS Ethernet and FPGA
RubenPadial
I need to receive some data with the HPS Ethernet with TCP/IP protocol, process them and share with the FPGA.
Is there any example or AN?
What are the steps to get a program to process the data in the SoC and share with the FPGA?
Thank you in advance.
KennyTan_Altera
Kindly take note that they will be some slowness on the first reply due to the public holiday, we will get back to you as soon as possible.
Jeet14
Which one you are targeting the baremetal application or Linux or MicroC/OS II ?
Tiwari
RubenPadial
I'm working on Linux.
Jeet14
In linux you need to write the socket programming to build the TCP/IP application over ethernet for server or client on board.
It is generic way of writing the linux TCP/IP app. For reference you can refer below link
https://www.geeksforgeeks.org/tcp-server-client-implementation-in-c/
For HPS & FPGA data transfer, please refer the below link. Same need to be implemented for Arria 10.
https://github.com/robertofem/CycloneVSoC-examples/tree/master/Linux-modules/DMA_PL330_LKM_basic
Tiwari
RubenPadial
Hello @Jeet14,
Thank you for this information.
If I'm not wrong, the example you sent me about DMA is to manage data between HPS and FPGA memories once data is received by an Linux client application in the HPS. That's very useful but it will be very helpful if you could give more details about how to build/run the client app for the Arria 10 HPS.
Jeet14
Let me know if you have any other query on this matter.
Tiwari
Jeet14
For your reference, you can follow steps as hello world application.
Add yocto application and compile using meta-bake.py script
$cd meta-intel-fpga-refdes/
$mkdir recipe-example
$mkdir helloworld
$cd helloworld
Add the .c & .h files and create the helloworld.bb file in helloworld directory. Snapshot from the helloworld.bb file.
$nano helloworld.bb
SUMMARY = "Example hello world" DESCRIPTION = "helloworld in HPS"
AUTHOR = "Test_engineer"
LICENSE = "BSD-3-Clause"
LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/BSD-3-Clause;md5=550794465ba0ec5312d6919e203a55f9
inherit systemd pkgconfig
SRC_URI = "file://helloworld.c
S = "${WORKDIR}"
do_compile() {
        ${CC} ${CFLAGS} ${LDFLAGS} helloworld.c -o helloworld
do_install() {
        install -d ${D}${bindir}
        install -m 0755 helloworld ${D}${bindir}
Tiwari
RubenPadial
Hello @Jeet14
Thanks for the information.
Is EDS needed to create the TCP/IP client application or the application to transfer data from HPS to FPGA memory?
Is it necessary to create a linux yocto with the custom applications/recipes?
Is there any detailed guide?
Jeet14
You need to use the EDS for creating the preloader or uboot.
For creating the linux userspace application, you need to use the host linux machine where you need to use the intel cross compiler or yocto application method.
please refer the create your project with timer example for arria 10. ethernet TCP/IP not availble but you are try the previous links and follow the same steps.
https://www.intel.in/content/www/in/en/support/programmable/support-resources/design-guidance/linux-developer.html
https://www.rocketboards.org/foswiki/Documentation/UsingYoctoExtendibleSdkForApplicationDevelopment
Tiwari
Jeet14
Let me know if you have any query on this.
Tiwari
Jeet14
I believe your enqury has been answered. With that, I now transition this thread to community support.
Thank you.
Tiwari
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
