6458 Discussions
Intel CYCLONE 10 GX FPGA_10CX085YU484I6GSP
I_am_Arunkumar
Hi ,
 I am Arun kumar. I have doubt regarding Cyclone 10GX FPGA. As i know that 10CX085YU484I6GSP fpga is the high static power part of 10CX085YU484I6G FPGA. But i need to know that whether PInouts,SYmbol,PCB footprint,Datasheet,Configuration guides are same for both FPGA10CX085YU484I6GSP and 10CX085YU484I6G or it will be different. If it is different pls share the related documents to me. It will be reaaly helpful for me to design.
Thanks and Regards,
Arun Kumar.S
AqidAyman_Intel
Hello Arun Kumar,
Thank you for reaching out to Intel FPGA Community.
For your information, both 10CX085YU484I6GSP & 10CX085YU484I6G share the following:
- Datasheet – in operation conditions and timing
- Configuration guidelines
- Pinouts
- PCB footprint
As for the following, there are differences:
- Datasheet – in power consumption: 10CX085YU484I6GSP is having higher power compared to 10CX085YU484I6G. Both OPNs are tested with same test program, but 10CX085YU484I6GSP will be max 35% higher power than 10CX085YU484I6G in general.
- Symbol: 10CX085YU484I6GSP is marked the same way as its Part Number i.e. with extra “SP” in the Part Number, as compared to 10CX085YU484I6G.
I hope this information helps you.
Aqid Ayman
AqidAyman_Intel
Hello Arun,
Just drop by to check if you have any update on this? Did you find the solution given useful?
Aqid Ayman
I_am_Arunkumar
Hello Aqid,
                 The information you shared is very useful.
                 Thank you for your support.
Arunkumar.S
AqidAyman_Intel
Hi Arun,
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
