- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Dear Intel FPGA Support Team,
I am currently working with the Agilex™ 5 Modular Development Kit. Upon initial setup, the board functioned as expected. We successfully ran the Built-In Self-Test (BIST), and subsequently programmed the board with official Intel demonstration .sof files via JTAG without issue.
However, on the following day, the board suddenly became unresponsive to JTAG programming. The Quartus Programmer now reports the following error:
Info (213045): Using programming cable "Agilex_5E MDK Carrier [1-2.1]"
1) Agilex_5E MDK Carrier [1-2.1]
Unable to read device chain – JTAG chain broken
This issue occurred without any change in hardware setup or configuration. It is unexpected and has blocked further development.
Actions Taken:
Verified switch settings S13, S7, and S4 as per the Quick Start Guide.
Retried with multiple .sof files and different versions of Quartus.
Reconnected and tested the JTAG micro-USB cable, including using a known-working cable and port.
Powered cycle and rechecked all board connections.
Confirmed that the same error appears consistently across multiple host systems.
Request:
We kindly request your assistance in identifying the root cause of this sudden JTAG chain failure. Please advise on the recommended next steps for debugging or recovering the JTAG interface.
We have attached a screenshot of the Quartus Programmer and JTAG Chain Debugger for your reference.
Looking forward to your support to help restore JTAG programming capability on the Agilex 5 MDK.
Ganesh
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Can you use Quartus configuration debugger to see if the device power up successfully? (attached config debugger status)
regards,
Farabi
