Hello, |
I am Donald from TechAdvance Solutions. |
We are contracted by KITRON, to assist them in obtaining the subject data for the parts supplied by you. Please find the attached LOA from your Customer authorizing the same. |
The attached spreadsheet lists the parts supplied by you, for which the Customer is seeking the subject information. The cells which are blank are the ones which we are unable to get the information from your website. |
Kindly provide the below for the attached part list : |
Lifecycle Status : (Active/Obsolete/EOL/NRND) |
Last Time Buy (LTB) date ( If the input part is EOL ) |
RoHS 3 (2015/863/EU) Certificate of Compliance (URL/File Name) |
Alternate RoHS Compliant part if the input part is Obsolete/EOL/NRND/Non-RoHS |
REACH 235 SVHC certificate of Compliance (URL/File Name) |
SCIP reference number for SVHC present parts |
Feel free to contact me for any clarifications/ information. |
Thank you in advance. |
Regards, |
Donald |
Sourcing Engineer |
TechAdvance Solutions |
Hi @TechAdvance,
Thank you for posting in Intel community forum and hope all is well.
To clarify further on the request, what Intel specific are you looking at?
Is this FPGA related?
Best Wishes
BB
Hi @TechAdvance,
Greetings, just checking in to see if there is any further doubts in regards to this matter.
Hope your doubts have been clarified.
Best Wishes
BB
Hello BB,
Yes. Please find the attached documents regarding our request.
Kindly let me know if you have any questions.
Donald.
Hi @TechAdvance,
Noted on the situation and request for the fpga parts life cycle status.
We are getting in touch with the relevant teams with the required information and will get back to you at earliest.
Thank you for the patients.
Best Wishes
BB
Good day
Thank you for reaching out. I'm Nazrul Naim looking into your request and allow me some time to look into your request. I shall come back to you with the information needed.
Thank you for your patience.
Nazrul Naim
Sorry for the delay. Below I will attach the Excel file for the information needed. As for the highlighted device MPN, can you please confirm back the MPN because the ones that are been highlighted cannot be found in our database.
As for the ROHS information, it can be obtained through the link that I will provide below.
Link : Material Declaration Data Sheets (MDDS) (intel.com)
Do let me know if you need further assistance regarding this request.
Nazrul Naim
Hello Nazrul,
Thank you for your email and information. I will check internally and get back to you.
Have a nice day!!.
Donald.
Hello Nazrul,
Good day. Please find the below feedback from my tech team and do the needful.
"We were unable to get information for the below parts in the MDDS link, Please provide."
KITRON Part Number | Description | MFR | MPN |
4102065 | IC FPGA ARRIA 220K CELLS 344 I/O FBGA780 | INTEL | 10AS022E5F29I3SG |
4092796 | IC FPGA 396 I/O 10AX066K2F35 1152FCBGA | INTEL | 10AX066K2F35I2SGES |
4088004 | IC FPGA ARRIA 10 ES2 1.0V BGA1152 | INTEL | 10AX115H2F34I2SGE2 |
4117195 | IC FPGA | INTEL | 10CX085YU484E6 |
4071233 | IC FPGA 5SGXA3 BGA1517 | INTEL | 5SGXMA3K3F40CN |
4007664 | CABLAGE PARALLEL PORT DOWNLOAD CABLE | INTEL | Byteblaster MV parallelport DL |
4129635 | IC FPGA PLCC44 | INTEL | EP1800ILC-70 |
4128651 | IC EP1810 EPLD EPROM | INTEL | EP1810LC-35T |
4033562 | IC PLD EP1810LC 45NS PLCC | INTEL | EP1810LC-45 |
4048066 | IC PAL 85C220 DIL20 | INTEL | EP220DI |
4129020 | FPGA EP3C10F256C8 | INTEL | EP310F256C8 |
4044728 | IC FPGA EP4S40G2F40I2N BGA1517 | INTEL | EP4S40G2F40I2NGB |
4129829 | IC FPGA PLCC28 | INTEL | EP610PC-25 |
4129829 | IC FPGA PLCC28 | INTEL | EP610PC-30 |
4002922 | IC EPLD EP910ILC 15NS PLCC44 | INTEL | EP910ILC-15 |
4129151 | IC PAL LOGIC CMOS PLCC44 | INTEL | EP910LC-35 |
4033575 | IC EPLD EP910LI 35NS OTP PLCC | INTEL | EP910LI-35 |
4003222 | IC EPLD EP910PC 30NS DIL40 | INTEL | EP910PC-30 |
4003760 | IC EPROM 16MHZ EPC16 BGA88 | INTEL | EPC16U88 |
4121183 | IC CONFIG DEVICE 1MBIT 8SOIC | INTEL | EPCS1SC8 |
4034334 | IC EPLD EPF10K10ATC100-2 TQFP | INTEL | EPF10K10ATC100-2N |
4121189 | IC FPGA 185 I/O INTEL 240QFP | INTEL | EPIC6Q240C8N |
4129281 | IC EPLD, BLANK | INTEL | EPM5130LC |
4124543 | IC PROGRAMMABLE LOGIC DEVICE | INTEL | EPM7032JC44-3 |
4120919 | IC FPGA EEPROM 512K 8DIP, BLANK | INTEL | F2341 |
Donald.
Hi Donald,
Thank you for the update. Allow me some time to obtain all the information needed as you requested.
Nazrul Naim
I'm sorry for the delay. Below are the details of information as requested. For your information, most of these devices are either Obsolete/EOL and the sources for these devices are really limited.
10AS022E5F29I3SG - This part number is invalid in Intel Database
10AX066K2F35I2SGES - https://cdrdv2.intel.com/v1/dl/getContent/691990?fileName=10AX066K2F35I2SG_20191127095238_v1.xml
10AX115H2F34I2SGE2 - https://cdrdv2.intel.com/v1/dl/getContent/692862?fileName=10AX115H2F34I2SG_20191127165824_v1.xml
10CX085YU484E6 - This part number is invalid in Intel Database
5SGXMA3K3F40CN - This part number is invalid in Intel Database
Byteblaster MV parallelport DL - No MDDS available
EP1800ILC-70 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP1810LC-35T - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP1810LC-45 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP220DI - https://cdrdv2.intel.com/v1/dl/getContent/677856?explicitVersion=true&fileName=pdn9508.pdf
EP310F256C8 - This part number is invalid in Intel Database
EP4S40G2F40I2NGB - https://cdrdv2.intel.com/v1/dl/getContent/701889?fileName=EP4S40G2F40I2N_20191201044322_v1.xml
EP610PC-25 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP610PC-30 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP910ILC-15 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP910LC-35 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP910LI-35 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP910PC-30 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EPC16U88 - Does not have MDDS
EPCS1SC8 - Please kindly note that the Intel® Enpirion® Power Product family is obsolete per Product
Discontinuance Notice PDN2133.With this obsolescence, we no longer retain Enpirion design, applications, testing, or failure
analysis capabilities and are unable to provide failure analysis services for Enpirion products.
EPF10K10ATC100-2N - https://cdrdv2.intel.com/v1/dl/getContent/699140?fileName=EPF10K10ATC100-2_20191201105555_v1.xml
EPIC6Q240C8N - This part number is invalid in Intel Database
EPM5130LC - Does not have MDDS
EPM7032JC44-3 - This part number is invalid in Intel Database
F2341 - This part number is invalid in Intel Database
Hope this answers your question.
Nazrul Naim
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Nazrul Naim
