6472 Discussions
Linux fails to boot on DE10-Nano board
YasuoF
I try to build a Linux file system for my DE10-Nano board,
When I write sdcard_cv.img to the SD card and power it on, it stops at the following line and Linux does not boot.
[    1.578872] Synopsys Designware Multimedia Card Interface Driver
What does this log mean?
And how can I fix the problem?
- My working environment is shown below.
Windows 10
Ubuntu 22.04.3 LTS on WSL2
Quartus Prime Version 23.1std.0 Build 991 11/28/2023 SC Standard Edition
- The procedure for creating an sd card image is shown below.
# Create working derectory
cd ~
mkdir de10nano-sample && cd de10nano-sample
# Setup toolchain
tar xf gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf.tar.xz
rm gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf.tar.xz
export PATH=`pwd`/gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf/bin:$PATH
# Get hardware project (Windows)
Download the DE10-Nano CD-ROM (rev.C Hardware) from here (https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=167&No=1046&PartNo=4#contents) and unzip the file.
Open Demonstrations/Soc_FPGA/DE10_NANO_SOC_GHRD/DE10_NANO_SoC_GHRD.qpf with Quartus.
Open soc_system.qsys in Platform Designer and generate HDL.
Add soc_system/synthesis/soc_system.qip to the project and Start Compilation.
Copy to a working directory in Ubuntu.
# Get bootloader
cd ~/de10nano-sample
cd u-boot-socfpga/arch/arm/mach-socfpga/cv_bsp_generator
python2 cv_bsp_generator.py \
-i ~/de10nano-sample/DE10_NANO_SoC_GHRD/hps_isw_handoff/soc_system_hps_0 \
-o ~/de10nano-sample/u-boot-socfpga/board/altera/cyclone5-socdk/qts
cd ~/de10nano-sample/u-boot-socfpga
export ARCH=arm
export CROSS_COMPILE=arm-none-linux-gnueabihf-
make socfpga_cyclone5_defconfig
make -j 48
# Get dtb
cd sopc2dts && sudo apt install default-jdk && make
cd ~/de10nano-sample/DE10_NANO_SoC_GHRD
java -jar ~/de10nano-sample/sopc2dts/sopc2dts.jar \
--input soc_system.sopcinfo \
--output soc_system.dtb \
--type dtb \
--board hps_isw_handoff/soc_system_hps_0/hps.xml \
--board hps_isw_handoff/soc_system_hps_0/emif.xml \
--clocks
# Get zImage
cd linux-socfpga
make socfpga_defconfig
make zImage Image modules -j 48
make modules_install INSTALL_MOD_PATH=modules_install
rm -rf modules_install/lib/modules/*/build
rm -rf modules_install/lib/modules/*/source
# Get RootFs
mkdir rootfs && cd rootfs
git clone -b kirkstone https://git.yoctoproject.org/poky
source poky/oe-init-build-env ./build
echo 'MACHINE = "cyclone5"' >> conf/local.conf
echo 'BBLAYERS += " ${TOPDIR}/../meta-intel-fpga "' >> conf/bblayers.conf
bitbake core-image-minimal
# Get SD card image
mkdir sd-card
mkdir -p sd-card/sdfs/extlinux
mkdir -p sd-card/rootfs
cp u-boot-socfpga/u-boot-with-spl.sfp sd-card
cp linux-socfpga/arch/arm/boot/zImage sd-card/sdfs
cp DE10_NANO_SoC_GHRD/soc_system.dtb sd-card/sdfs
sudo tar xf rootfs/build/tmp/deploy/images/cyclone5/core-image-minimal-cyclone5.tar.gz -C sd-card/rootfs
sudo rm -rf sd-card/rootfs/lib/modules/*
sudo cp -r linux-socfpga/modules_install/lib/modules/*/* sd-card/rootfs/lib/modules
cd ~/de10nano-sample/sd-card
chmod +x make_sdimage_p3.py
# Edit make_sdimage_p3.py line 455
# ["-F 32", "-I"] -> ["-F", "32", "-I"]
echo "LABEL Linux Default" > sdfs/extlinux/extlinux.conf
echo "    KERNEL ../zImage" >> sdfs/extlinux/extlinux.conf
echo "    FDT ../soc_system.dtb" >> sdfs/extlinux/extlinux.conf
echo "    APPEND root=/dev/mmcblk0p2 rw rootwait earlyprintk console=ttyS0,115200n8" >> sdfs/extlinux/extlinux.conf
sudo python3 make_sdimage_p3.py -f \
-P u-boot-with-spl.sfp,num=3,format=raw,size=10M,type=A2 \
-P sdfs/*,num=1,format=fat32,size=100M \
-P rootfs/*,num=2,format=ext3,size=300M \
-s 512M \
-n sdcard_cv.img
Thanks & Regards
YasuoF
As an addendum to the above description,
If I replace the dtb with socfpga_cyclone5_socdk.dtb in ~/de10nano-sample/linux-socfpga/arch/arm/boot/, LINUX will boot.
Based on the above facts, we believe that there is a mistake in the way the dtb was created.
aikeu
Hi YasuoF,
Can share the full boot up logs error for linux?
Would like to see if any particular failure indication from there.
Terasic DE10 is using Cylone V architecture, can check if there is any difference on the device tree configuration used by Cyclone V:
https://github.com/altera-opensource/linux-socfpga/blob/socfpga-6.1.55-lts/arch/arm/boot/dts/socfpga_cyclone5_socdk.dts
Aik Eu
YasuoF
Hi, @aikeu
The reason it stopped at that line was due to a bad terminal setting, and the scrolling just stopped in the middle of the line.
I apologize for the inconvenience.
However, Linux still does not boot.
It appears that mmcblk0p2 cannot be opened. How can I resolve this issue?
I'll upload the correct log as bootup-log.txt.
Also, I have compared the dts uploaded to Github with the dts created by the above procedure, but there are too many differences to discern what is causing the problem.
aikeu
Hi YasuoF,
I not familiar with the error to be specific and it seems that it has something to do with the rootfs does not match with the kernel.
I am thinking if we can compare and check with some pre-built images first from rocketboards release for cyclone 5:
https://releases.rocketboards.org/2022.11/gsrd/c5_gsrd/
Aik Eu
aikeu
Hi YasuoF,
May I know any new follow up on the case?
Aik Eu
YasuoF
Hi @aikeu
Currently, no progress has been made.
I will report back if any progress is made.
Due to priorities, I can no longer work on this topic for a few months, so you may close this topic.
Thanks & Regards
aikeu
Hi YasuoF,
I will close the thread first. Do consider re-open a new thread if there is new follow up.
Aik Eu
