6478 Discussions
Program LMK04828 Clock Cleaner on Arria 10 SoC Dev Kit
elabarge
I'm using the Arria 10 SoC Dev Kit: https://tinyurl.com/y8njd2pk
I would like to program the LMK04828 Clock Cleaner to output a specific frequency. The TI program TICS Pro doesn't work for this Arria 10 SoC dev kit. It only works for the LMK evaluation module (LMK04828BEVM).
Can you please provide the correct software to program the LMK04828.
There are multiple posts asking this same question and each one results in a private message to the original poster with a zip file of the correct software:
https://tinyurl.com/yaxukjt2
https://tinyurl.com/ybypq7cs
Why isn't this available to the public somewhere on this website? Or is it and I just can't find it?
aikeu
Hi elabarge,
I am trying to get the info which you are looking for and will feedback to you soon.
Aik Eu
elabarge
Sounds good @aikeu . I look forward to hearing from you.
Best,
aikeu
Hi elabarge,
I have sent you an email regarding the clock cleaner.
Aik Eu
aikeu
Hi elabarge,
I will close this thread if no further questions.
Aik Eu
elabarge
Hi @aikeu,
The ftp you provided was empty and I have still not received the files. Any help would be greatly appreciated.
aikeu
Hi elabarge,
Sorry about that, when I login, I cant see the file also.
I have reupload the file again. Can try check again.
Do let me know if there is any problem.
Aik Eu
elabarge
Success!
I received the files. Thank you.
Can you make these files available to the public on this website or the main Intel website?
aikeu
Hi elabarge,
I will try to ask whether I can make this file access to public.
I will close this thread for now, do raise another thread if there is further quesion.
Other than that, do give me a good survey for my support if received any survey request.
Aik Eu
Alberte
I am currently having the exact same issue here. I am using the Arria 10 SoC Dev Kit and would like to be able to program the LMK device. Where can I find the information on how to do it?
Greetings,
Alberte
