Hi, I wrote this code so that I could display the number on putty which is being represented by LEDS on my Cyclone V board. The leds on board are working perfectly fine. But the output on my putty terminal is not working. For example, if I type ./program_name 8 then it will display §§§ or just 173. Any ideas where is the error?
Attach is the file for my code
regget.c
(Virus scan in progress ...)
Can you look at the baud rate setting ? May I know which FPGA you are using in your design ? Also can share the FPGA design file ?
Thank you,
Sree
