5780 Discussions
Quartus prime pro 19.1 always crashes on my project using arria 10 FPGA.
AEsqu
Quartus 13.1 on Stratix 3 FPGA has no problem with the same project (aside specific PLL/RAM/ROM,IO BUFFERS components).
See attached crash message.
Entry is a vqm from synplify pro 2019.09 (same for stratix 3 project).
AEsqu
When I change some synthesis option, Quartus 19.1 goes further but crashes with another error,
see second attachment.
RichardTanSY_Intel
Hi, can you share your design that can duplicate this error?
What are the change made in the synthesis option that crashes with the second error?
AEsqu
No, I cannot share it.
Below the options I changed, not sure which one affects the run:
set_global_assignment -name SYNTH_TIMING_DRIVEN_SYNTHESIS OFF
set_global_assignment -name FRACTAL_SYNTHESIS OFF
set_global_assignment -name MUX_RESTRUCTURE OFF
set_global_assignment -name INFER_RAMS_FROM_RAW_LOGIC OFF
set_global_assignment -name OPTIMIZATION_TECHNIQUE SPEED
set_global_assignment -name AUTO_ROM_RECOGNITION OFF
set_global_assignment -name AUTO_RAM_RECOGNITION OFF
set_global_assignment -name AUTO_DSP_RECOGNITION OFF
set_global_assignment -name AUTO_SHIFT_REGISTER_RECOGNITION OFF
set_global_assignment -name AUTO_CLOCK_ENABLE_RECOGNITION OFF
set_global_assignment -name OPTIMIZE_POWER_DURING_SYNTHESIS OFF
set_global_assignment -name HDL_MESSAGE_LEVEL LEVEL3
set_global_assignment -name BLOCK_DESIGN_NAMING QUARTUSII
set_global_assignment -name SYNTH_MESSAGE_LEVEL HIGH
set_global_assignment -name ALLOW_REGISTER_MERGING OFF
set_global_assignment -name ALLOW_REGISTER_DUPLICATION OFF
set_global_assignment -name BLOCK_RAM_TO_MLAB_CELL_CONVERSION OFF
set_global_assignment -name OPTIMIZE_IOC_REGISTER_PLACEMENT_FOR_TIMING OFF
set_global_assignment -name FINAL_PLACEMENT_OPTIMIZATION NEVER
set_global_assignment -name FITTER_AGGRESSIVE_ROUTABILITY_OPTIMIZATION NEVER
set_global_assignment -name QII_AUTO_PACKED_REGISTERS OFF
set_global_assignment -name AUTO_DELAY_CHAINS OFF
set_global_assignment -name FITTER_EFFORT "STANDARD FIT"
set_global_assignment -name ROUTER_LCELL_INSERTION_AND_LOGIC_DUPLICATION OFF
set_global_assignment -name ROUTER_REGISTER_DUPLICATION OFF
set_global_assignment -name DSP_BLOCK_BALANCING OFF
set_global_assignment -name ROUTER_CLOCKING_TOPOLOGY_ANALYSIS ON
RichardTanSY_Intel
I understand that you can not share your design due to confidential.
If possible, could you create a simplified design that can duplicate the same error? Our engineering team need a design in order to do any further debug.
sstrell
Also, how much RAM does the computer you are using for compilation have?
You may also want to try trashing the qdb folder in your project directory before compiling to make sure there is no corruption from a prior compilation.
#iwork4intel
AEsqu
Plenty of RAM:
Removing qdb does not help.
I will have quartus 19.3 installed soon, let's see how it goes.
Your job looked like:
# LSBATCH: User input
quartus Achilles_arria_X.qpf
Successfully completed.
Resource usage summary:
   CPU time :                                  3958.68 sec.
   Max Memory :                                10099 MB
   Average Memory :                            3414.17 MB
   Total Requested Memory :                    48000.00 MB
   Delta Memory :                              37901.00 MB
   Max Swap :                                  -
   Max Processes :                             15
   Max Threads :                               175
   Run time :                                  21003 sec.
   Turnaround time :                           21004 sec.
AEsqu
Quartus 19.3 also crashes.
Error example below:
Problem Details
Error:
Internal Error: Sub-system: FTI, File: /quartus/h/fti_utils_sys.h, Line: 93
a.is_valid() && b.is_valid()
Stack Trace:
  0xa1523: (tsm_fti)
  0xb029d: void FTI_SUBDOMAIN_CLOCK_DELAYS::compute_delays<(FTI_NETLIST_MODE)0>(FTI_NETLIST<(FTI_NETLIST_MODE)0> const&, FTI_SUBDOMAIN_VIEW const&, FTI_LPSP_TYPE, FTI_NODE_CLOCK_DELAY_CACHE const&)::{lambda(tbb::blocked_range<QTL_TRANSFORM_RANDOM_ACCESS_ITER<FTI_SUBDOMAIN_VIEW::get_range_entries_in_subdomain() const::TRANSFORM, __gnu_cxx::__normal_iterator<FTI_STRONG_ID<FTI_EDGE_ID_TAG, unsigned int> const*, std::vector<FTI_STRONG_ID<FTI_EDGE_ID_TAG, unsigned int>, std::allocator<FTI_STRONG_ID<FTI_EDGE_ID_TAG, unsigned int> > > >, FTI_SUBDOMAIN_EDGE_ENTRY_VIEW> > const&)#1}::operator()(tbb::blocked_range<QTL_TRANSFORM_RANDOM_ACCESS_ITER<FTI_SUBDOMAIN_VIEW::get_range_entries_in_subdomain() const::TRANSFORM, __gnu_cxx::__normal_iterator<FTI_STRONG_ID<FTI_EDGE_ID_TAG, unsigned int> const*, std::vector<FTI_STRONG_ID<FTI_EDGE_ID_TAG, unsigned int>, std::allocator<FTI_STRONG_ID<FTI_EDGE_ID_TAG, unsigned int> > > >, FTI_SUBDOMAIN_EDGE_ENTRY_VIEW> > const&) const + 0x38d (tsm_fti)
  0xb0854: tbb::interface9::internal::start_for<tbb::blocked_range<QTL_TRANSFORM_RANDOM_ACCESS_ITER<FTI_SUBDOMAIN_VIEW::get_range_entries_in_subdomain() const::TRANSFORM, __gnu_cxx::__normal_iterator<FTI_STRONG_ID<FTI_EDGE_ID_TAG, unsigned int> const*, std::vector<FTI_STRONG_ID<FTI_EDGE_ID_TAG, unsigned int>, std::allocator<FTI_STRONG_ID<FTI_EDGE_ID_TAG, unsigned int> > > >, FTI_SUBDOMAIN_EDGE_ENTRY_VIEW> >, void FTI_SUBDOMAIN_CLOCK_DELAYS::compute_delays<(FTI_NETLIST_MODE)0>(FTI_NETLIST<(FTI_NETLIST_MODE)0> const&, FTI_SUBDOMAIN_VIEW const&, FTI_LPSP_TYPE, FTI_NODE_CLOCK_DELAY_CACHE const&)::{lambda(tbb::blocked_range<QTL_TRANSFORM_RANDOM_ACCESS_ITER<FTI_SUBDOMAIN_VIEW::get_range_entries_in_subdomain() const::TRANSFORM, __gnu_cxx::__normal_iterator<FTI_STRONG_ID<FTI_EDGE_ID_TAG, unsigned int> const*, std::vector<FTI_STRONG_ID<FTI_EDGE_ID_TAG, unsigned int>, std::allocator<FTI_STRONG_ID<FTI_EDGE_ID_TAG, unsigned int> > > >, FTI_SUBDOMAIN_EDGE_ENTRY_VIEW> > const&)#1}, tbb::static_partitioner const>::execute() + 0x1d4 (tsm_fti)
  0x27156: tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 0x536 (tbb)
  0x1fd58: tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 0x1e8 (tbb)
  0x1e84b: tbb::internal::market::process(rml::job&) + 0x1b (tbb)
  0x1aac5: tbb::internal::rml::private_worker::run() + 0x65 (tbb)
  0x1ad09: tbb::internal::rml::private_worker::thread_routine(void*) + 0x9 (tbb)
   0x7aa1: (pthread)
  0xe8bcd: clone + 0x6d (c)
End-trace
Executable: quartus_fit
Comment:
None
System Information
Platform: linux64
OS name: Red Hat
OS version: 6
Quartus Prime Information
Address bits: 64
Version: 19.3.0
Build: 222
Edition: Pro Edition
AEsqu
Quartus 19.3 also crashes when I use Quartus synthesis (no vqm from synplify pro):
Problem Details
Error:
Stack Trace:
  0xa1523: (tsm_fti)
  0x23b00: tbb::internal::generic_scheduler::local_spawn_root_and_wait(tbb::task*, tbb::task*&) + 0xa0 (tbb)
  0xa4033: std::pair<FTI_STRONG_VEC<std::vector<FTI_GB_SUBDOMAIN_INFO, std::allocator<FTI_GB_SUBDOMAIN_INFO> >, FTI_STRONG_ID<FTI_SUBDOMAIN_ID_TAG, unsigned int> >, bool> (anonymous namespace)::compute_all_subdomain_info<(FTI_NETLIST_MODE)0>(FTI_TIMING_RESULTS const&, FTI_NETLIST<(FTI_NETLIST_MODE)0> const&, FTI_LPSP_TYPE, FTI_CORNER_TYPE, FTI_SLACK_GUARDBAND_PARAMS const&, FTI_GB_SCALING_FACTORS const&, bool)::{lambda(tbb::blocked_range<FTI_STRONG_ID<FTI_SUBDOMAIN_ID_TAG, unsigned int> > const&)#1}::operator()(tbb::blocked_range<FTI_STRONG_ID<FTI_SUBDOMAIN_ID_TAG, unsigned int> > const&) const + 0xb63 (tsm_fti)
  0xa458d: tbb::interface9::internal::start_for<tbb::blocked_range<FTI_STRONG_ID<FTI_SUBDOMAIN_ID_TAG, unsigned int> >, std::pair<FTI_STRONG_VEC<std::vector<FTI_GB_SUBDOMAIN_INFO, std::allocator<FTI_GB_SUBDOMAIN_INFO> >, FTI_STRONG_ID<FTI_SUBDOMAIN_ID_TAG, unsigned int> >, bool> (anonymous namespace)::compute_all_subdomain_info<(FTI_NETLIST_MODE)0>(FTI_TIMING_RESULTS const&, FTI_NETLIST<(FTI_NETLIST_MODE)0> const&, FTI_LPSP_TYPE, FTI_CORNER_TYPE, FTI_SLACK_GUARDBAND_PARAMS const&, FTI_GB_SCALING_FACTORS const&, bool)::{lambda(tbb::blocked_range<FTI_STRONG_ID<FTI_SUBDOMAIN_ID_TAG, unsigned int> > const&)#1}, tbb::auto_partitioner const>::execute() + 0x1ad (tsm_fti)
   0x7aa1: (pthread)
  0xe893d: clone + 0x6d (c)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: linux64
OS name: Red Hat
OS version: 6
Address bits: 64
Version: 19.3.0
Build: 222
Attaching the constrain file in case that helps figuring out the issue (it is the arriaX if checks).
AEsqu
set current_project Achilles_arria_X
set is_a_synplify_project 0
set is_a_quartus_project 1
AEsqu
Quartus pro 19.3 ran ok for 6 hours till the end when I removed the complete constraint file
(I did that because the crash message was pointing to that).
So Quartus has some issue with the SDC.
I will have have to check which one makes it crash.
If you have any suggestion, tell me.
AEsqu
Those constraints below makes quartus 19.3 arria x to crash (quartus 13.1 stratix 3 is ok with):
set max_input_delay 9
set max_output_delay 23
set_max_delay -from [get_ports *] $max_input_delay
set_max_delay -to  [get_ports *] $max_output_delay
AEsqu
  set min_input_delay 0
  set min_output_delay 0
  set_min_delay -to  [get_ports *] $min_output_delay
Also makes it crash at the end of the fitter (max delay was making it crash at the end of synthesis).
Removing it too.
AEsqu
The fractal synthesis also crashes quartus 19.3 synthesis when it uses a vqm from Synplify pro:
Problem Details
Error:
Internal Error: Sub-system: OPT, File: /quartus/synth/opt/opt_carry_pack.cpp, Line: 956
opt_can_convert_a10_arith_gate_to_shared_mode(sgate)
Stack Trace:
  0xf6b3d: opt_convert_a10_gate_with_no_sumout(CDB_SGATE_NODE*) + 0x49 (synth_opt)
  0xf7688: OPT_CARRY_PACK::prepare_chain(CDB_SGATE_NETLIST*, OPT_CHAIN&, bool) + 0x732 (synth_opt)
  0xf5957: OPT_CARRY_PACK::apply_packing_solution(CDB_SGATE_NETLIST*, std::vector<OPT_BIN, std::allocator<OPT_BIN> >&) + 0x5d (synth_opt)
  0xf4d6f: OPT_CARRY_PACK::pack_carry_chains(CDB_SGATE_NETLIST*) [clone .cold.248] + 0x739 (synth_opt)
  0x201d22: opt_run_carry_chain_packer(CMP_FACADE*, CDB_SGATE_NETLIST*) + 0x32 (synth_opt)
  0x4ef41: FTM_ROOT_IMPL::postprocess() + 0x81 (synth_ftm)
  0x52ac8: FTM_ROOT_IMPL::start_normal_flow() + 0x2078 (synth_ftm)
  0x5466b: FTM_ROOT_IMPL::start() + 0x4b (synth_ftm)
  0x54a02: FTM_ROOT::start(CDB_SGATE_NETLIST*, SCL_WYSIWYG_ATOM_FACTORY*) + 0x92 (synth_ftm)
  0x68c61: SCL_SYN_HIER::do_tech_mapping(CDB_SGATE_NETLIST*) + 0x305 (synth_scl)
  0x2a9c3: scl_run_ftm(CMP_FACADE*, SAM_FACADE*, CDB_SGATE_HIERARCHY*, CDB_SGATE_NETLIST*) + 0x8f (synth_scl)
  0x122f0d: SYNTH::QIS::SYNTHESIS_FLOW::ftm() + 0x39 (synth_qis)
  0x12882a: SYNTH::QIS::SYNTHESIS_FLOW::run_current_phase() + 0x21e (synth_qis)
  0x128d1f: SYNTH::QIS::SYNTHESIS_FLOW::run_full_flow(std::string const&, bool) + 0x361 (synth_qis)
  0x952c0: QIS_RTL_STAGE::IMPL::synthesize(QHD_PARTITION&, bool) + 0x322 (synth_qis)
  0x9550f: QIS_RTL_STAGE::synthesize(QHD_PARTITION&, bool) + 0xf (synth_qis)
  0x59bf9: qis_synthesize + 0x1cd (synth_qis)
  0x4c942: TclNRRunCallbacks + 0x42 (tcl8.6)
  0x4de7b: TclEvalEx + 0x68b (tcl8.6)
  0xf3f0e: Tcl_FSEvalFileEx + 0x25e (tcl8.6)
  0xf3ffe: Tcl_EvalFile + 0x2e (tcl8.6)
  0x14916: qexe_evaluate_tcl_script(std::string const&) + 0x44c (comp_qexe)
  0x19a1c: qexe_do_tcl(QEXE_FRAMEWORK*, std::string const&, std::string const&, std::list<std::string, std::allocator<std::string> > const&, bool, bool) + 0x417 (comp_qexe)
  0x1a9d5: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x558 (comp_qexe)
  0x3922e: QCU::DETAIL::intialise_qhd_and_run_qexe(QCU_FRAMEWORK&, FIO_PATH const&, std::string const&, std::string const&, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0xed (comp_qcu)
  0x41d1c: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x259 (comp_qcu)
  0x405bb7: qsyn2_tcl_process_default_flow_option(ACF_VARIABLE_TYPE_ENUM, char const*) + 0x9d (quartus_syn)
  0x1d69e: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x6a0 (comp_qexe)
  0x40571b: qsyn2_main(int, char const**) + 0x14b (quartus_syn)
  0x3ef00: msg_main_thread(void*) + 0x10 (ccl_msg)
  0x41114: msg_thread_wrapper(void* (*)(void*), void*) + 0x6e (ccl_msg)
  0x11f0c: mem_thread_wrapper(void* (*)(void*), void*) + 0x5c (ccl_mem)
   0xc728: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err)
   0x6d85: thr_thread_wrapper + 0x15 (ccl_thr)
  0x41c90: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0x148 (ccl_msg)
  0x405da0: main + 0x26 (quartus_syn)
  0x1ed1d: __libc_start_main + 0xfd (c)
  0x4054f9: (quartus_syn)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: linux64
OS name: Red Hat
OS version: 6
Address bits: 64
Version: 19.3.0
Build: 222
AEsqu
Update: It is important to define the IO delay at the end of the sdc file,
because quartus does not know yet the clock definition when get_clocks * is used at the top.
I moved them at the bottom and I don't use get_clocks * anymore,
I define each pin with respective clock, using -add_delay when necessary (multiple clock domain per pin)..
