6472 Discussions
Regarding Ethernet /Transceiver tool kit error in F tile 10G Hard IP for AGFB027R24C FPGA device
Maitry
Hello support team,
We are using AGFB027R24C2I3E Agilex F series FPGA in our custom board. With Bank 13 A, 156.25 MHz (i_refclk2pll_clk) clock is interfaced ( CH6 = CJ7, CH8). And Tx, Rx is in CH1. Also, i_reconfig_clk is taken from CN41, CP40 ( 100 MHz differential ). As this board is custom board for AGFB027R24C2I3E. We have taken a reference example design from quartus 24.2 of F tile 10G hard IP using board type = None, refclk channel -6 and syspll = 322.26 MHz, single instance and generate the project, added above pin mapping and clock settings. and generate .SOF File for 10G. For the validation , We are loopback the SFP module Tx with Rx, load the .SOF file and open In system source and probes editor in which we assert and deassert the source . but there is no indication or changes in the probes. and while opening the ethernet tool kit, we are getting below error.
Error 1: F-Tile Ethernet Intel FPGA Hard IP: dut_jtag_master
SEVERE: An error occurred while running script "init_toolkit
": F-Tile Ethernet Intel FPGA Hard IP: dut_jtag_master: expected integer but got ""
while executing
"format "0x%x" $gui_option"
(procedure "pysv_package::pysv_callback" line 42)
invoked from within
(procedure "init_toolkit" line 13)
invoked from within
"init_toolkit"
Error 2: F-Tile Ethernet Intel FPGA Hard IP: dut_jtag_master
SEVERE: An error occurred while running script "finalize_toolkit
": F-Tile Ethernet Intel FPGA Hard IP: dut_jtag_master: can't read "master_claim_path": no such variable
while executing
"close_service master $master_claim_path"
(procedure "common_driver_pkg::close_port" line 6)
invoked from within
(procedure "finalize_toolkit" line 5)
invoked from within
"finalize_toolkit"
Can you provide the feedback and guidance on why We are getting the above error and how to resolve it.
FYI : My QSFP connector is FTE8510K1LTY.
Maitry
Hello support team,
Is there any feedback on the above
Maitry
By changing CH6 to CH0 in the F tile 10G hard IP, My ethernet tool kit enabled. I have made a loopback. But after enable internal loopback and start reading all status, My Tx PLL lock status is = locked . but My Rx PCS ready status = not ready and Rx CDR locked status = Not locked.
What is the reason behind this above issue? Is there anything that we are missing over here?
paveetirrasrie_Intel
Good day to you.
May I know if the reset signals have been deasserted or not? This is because rx_pcs_ready deasserts when i_rx_rst_n/i_rst_n signal asserts or during the auto-negotiation and link training operation.
And also I would suggest you to try to generate design example using board type = Agilex devkit and compare the pin assignments to ensure the pin connections is same as devkit.
Pavee
Good day.
Just wanted to check with you, any update from your end?
Feel free to let me know if you have further query. Happy to help.
Pavee
We didn't hear from you since last update. If you have a new question, feel free to open a new thread to get the support from Altera experts.
Otherwise, the community users will continue to help you on this thread.
Thank you.
