6478 Discussions
Simple Socket Server link established(SGMII) but cannot telnet/ping
PJais1
Hello ,
I am using a Arria 10 Custom Board, and testing ethernet which is in SGMII mode. I have used a development kit reference design and changed the FPGA(10as066k2f40e1hg).
After building the design, I am testing using Nios II design template of Simple Socket Server .
The Nios II console window shows below output:
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
altera_eth_tse_init 0
prep_tse_mac 0
Inside get_mac_addr
Inside get_ip_addr function
Static IP Address is 192.168.0.61
prepped 1 interface, initializing...
tse_mac_init 0
List of PHY profiles supported (Total profiles = 5)...
Profile No. 0  :
PHY Name    : Marvell 88E1111
PHY OUI     : 0x005043
PHY Model Num. : 0x0c
PHY Rev. Num.  : 0x02
Status Register : 0x11
Speed Bit    : 14
Duplex Bit   : 13
Link Bit    : 10
Profile No. 1  :
PHY Name    : Marvell Quad PHY 88E1145
PHY OUI     : 0x005043
PHY Model Num. : 0x0d
Speed Bit    : 14
Duplex Bit   : 13
Link Bit    : 10
Profile No. 2  :
PHY Name    : National DP83865
PHY OUI     : 0x080017
PHY Model Num. : 0x07
PHY Rev. Num.  : 0x0a
Speed Bit    : 3
Duplex Bit   : 1
Link Bit    : 2
Profile No. 3  :
PHY Name    : National DP83848C
PHY OUI     : 0x080017
PHY Model Num. : 0x09
PHY Rev. Num.  : 0x00
Status Register : 0x00
Speed Bit    : 0
Duplex Bit   : 0
Link Bit    : 0
Profile No. 4  :
PHY Name    : Intel PEF7071
PHY OUI     : 0x355969
PHY Model Num. : 0x00
PHY Rev. Num.  : 0x01
Speed Bit    : 0
Duplex Bit   : 0
Link Bit    : 0
INFO  : TSE MAC 0 found at address 0x00003000
INFO  : Multi Channel      = No
INFO  : MDIO Shared       = No
INFO  : MAC Type         = 10/100/1000 Ethernet MAC
INFO  : PCS Enable        = Yes
INFO  : PCS SGMII Enable     = Yes
INFO  : MAC Address       = 0x00003000
INFO  : MAC Device        = tse_mac_device[0]
INFO  : PHY Marvell 88E1111 found at PHY address 0x00 of MAC Group[0]
INFO  : PHY OUI       = 0x005043
INFO  : PHY Model Number  = 0x0c
INFO  : PHY Revision Number = 0x2
INFO  : PHY[0.0] - Automatically mapped to tse_mac_device[0]
INFO  : PHY[0.0] - Advertisement of 1000 Base-T Full Duplex set to 1
Created "Inet main" task (Prio: 2)
INFO  : PHY[0.0] - Advertisement of 1000 Base-T Half Duplex set to 1
INFO  : PHY[0.0] - Advertisement of 100 Base-T4 set to 0
INFO  : PHY[0.0] - Advertisement of 100 Base-TX Full Duplex set to 1
INFO  : PHY[0.0] - Advertisement of 100 Base-TX Half Duplex set to 1
INFO  : PHY[0.0] - Advertisement of 10 Base-TX Full Duplex set to 1
INFO  : PHY[0.0] - Advertisement of 10 Base-TX Half Duplex set to 1
INFO  : PHY[0.0] - Restart Auto-Negotiation, checking PHY link...
MARVELL : Mode changed to SGMII to Copper mode
MARVELL : Enable SGMII Timing Control
MARVELL : PHY reset
INFO  : PHY[0.0] - Auto-Negotiation PASSED
INFO  : Applying additional PHY configuration of Marvell 88E1111
INFO  : PCS[0.0] - Configuring PCS operating mode
INFO  : PCS[0.0] - PCS SGMII mode enabled
INFO  : PHY[0.0] - Checking link...
INFO  : PHY[0.0] - Link established
INFO  : PHY[0.0] - Speed = 1000, Duplex = Full
OK, x=0, CMD_CONFIG=0x00000000
MAC post-initialization: CMD_CONFIG=0x0400020b
[tse_msgdma_read_init] RX descriptor chain desc (9 depth) created
mctest init called
IP address of et1 : 192.168.0.61
Created "clock tick" task (Prio: 3)
Simple Socket Server starting up
[sss_task] Simple Socket Server listening on port 30
Created "simple socket server" task (Prio: 4)
Everything looks fine, but i am unable to route / telnet.
I have assigned same gateway and checked subnet mask.
Do i need to include:
marvell_cfg_sgmii((tse[iface].mi.base);
in ins_tse_mac.c  ?
Also what are additional changes for SGMII mode?
Deshi_Intel
Simple socket server template and reference design is typically used as it's reference design with min support.
It involved more on system level design which is not easy to debug.
However, if you are able to isolate the issue until TSE IP level then I may be able to help you out further.
  • For instance, can you duplicate issue using TSE IP only to isolate first is this data link or physical layer issue or network layer issue ?
  • Or do you see the data packet flow broken in somewhere ? NIOS -> DMA ? -> TSE -> PHY ?
dlim
Deshi_Intel
Another recommendation is to post your questions in rocket board forum.
That's the better community to discuss about SOC system level design issue where you can leverage the help from the right forum community user.
https://forum.rocketboards.org/
