Hi there,
I am trying to simulate some component SDRAM in QuestaSim. The SDRAM I need to model is the SDRAM on the DE10-Standard board.
I have the following model:
//Legal Notice: (C)2017 Altera Corporation. All rights reserved. Your
//use of Altera Corporation's design tools, logic functions and other
//software and tools, and its AMPP partner logic functions, and any
//output files any of the foregoing (including device programming or
//simulation files), and any associated documentation or information are
//expressly subject to the terms and conditions of the Altera Program
//License Subscription Agreement or other applicable license agreement,
//including, without limitation, that your use is for the sole purpose
//of programming logic devices manufactured by Altera and sold by Altera
//or its authorized distributors. Please refer to the applicable
//agreement for further details.
// synthesis translate_off
`timescale 1ns / 1ps
// synthesis translate_on
// turn off superfluous verilog processor warnings
// altera message_level Level1
// altera message_off 10034 10035 10036 10037 10230 10240 10030
module DE10_Standard_QSYS_sdram_test_component_ram_module (
// inputs:
data,
rdaddress,
rdclken,
wraddress,
wrclock,
wren,
// outputs:
q
output [ 15: 0] q;
input [ 15: 0] data;
input [ 24: 0] rdaddress;
input rdclken;
input [ 24: 0] wraddress;
input wrclock;
input wren;
logic [ 15: 0] mem_array [33554431: 0];
wire [ 15: 0] q;
reg [ 24: 0] read_address;
//synthesis translate_off
//////////////// SIMULATION-ONLY CONTENTS
always @(rdaddress)
begin
read_address = rdaddress;
end
// Data read is asynchronous.
assign q = mem_array[read_address];
//initial
// $readmemh("DE10_Standard_QSYS_sdram_test_component.dat", mem_array);
always @(posedge wrclock)
begin
// Write data
if (wren)
mem_array[wraddress] <= data;
end
//////////////// END SIMULATION-ONLY CONTENTS
//synthesis translate_on
//synthesis read_comments_as_HDL on
// always @(rdaddress)
// begin
// read_address = rdaddress;
// end
// lpm_ram_dp lpm_ram_dp_component
// .data (data),
// .q (q),
// .rdaddress (read_address),
// .rdclken (rdclken),
// .wraddress (wraddress),
// .wrclock (wrclock),
// .wren (wren)
// defparam lpm_ram_dp_component.lpm_file = "UNUSED",
// lpm_ram_dp_component.lpm_hint = "USE_EAB=ON",
// lpm_ram_dp_component.lpm_indata = "REGISTERED",
// lpm_ram_dp_component.lpm_outdata = "UNREGISTERED",
// lpm_ram_dp_component.lpm_rdaddress_control = "UNREGISTERED",
// lpm_ram_dp_component.lpm_width = 16,
// lpm_ram_dp_component.lpm_widthad = 25,
// lpm_ram_dp_component.lpm_wraddress_control = "REGISTERED",
// lpm_ram_dp_component.suppress_memory_conversion_warnings = "ON";
//synthesis read_comments_as_HDL off
endmodule
module DE10_Standard_QSYS_sdram_test_component (
// inputs:
clk,
zs_addr,
zs_ba,
zs_cas_n,
zs_cke,
zs_cs_n,
zs_dqm,
zs_ras_n,
zs_we_n,
// outputs:
zs_dq
inout [ 15: 0] zs_dq;
input clk;
input [ 12: 0] zs_addr;
input [ 1: 0] zs_ba;
input zs_cas_n;
input zs_cke;
input zs_cs_n;
input [ 1: 0] zs_dqm;
input zs_ras_n;
input zs_we_n;
wire [ 23: 0] CODE;
wire [ 12: 0] a;
wire [ 9: 0] addr_col;
reg [ 14: 0] addr_crb;
wire [ 1: 0] ba;
wire cas_n;
wire cke;
wire [ 2: 0] cmd_code;
wire cs_n;
wire [ 1: 0] dqm;
wire [ 2: 0] index;
reg [ 2: 0] latency;
wire [ 1: 0] mask;
wire [ 15: 0] mem_bytes;
wire ras_n;
reg [ 24: 0] rd_addr_pipe_0;
reg [ 24: 0] rd_addr_pipe_1;
reg [ 24: 0] rd_addr_pipe_2;
reg [ 1: 0] rd_mask_pipe_0;
reg [ 1: 0] rd_mask_pipe_1;
reg [ 1: 0] rd_mask_pipe_2;
reg [ 2: 0] rd_valid_pipe;
wire [ 24: 0] read_addr;
wire [ 15: 0] read_data;
wire [ 1: 0] read_mask;
wire [ 15: 0] read_temp;
wire read_valid;
wire [ 15: 0] rmw_temp;
wire [ 24: 0] test_addr;
wire [ 23: 0] txt_code;
wire we_n;
wire [ 15: 0] zs_dq;
initial
begin
$write("\n");
$write("************************************************************\n");
$write("This testbench includes an SOPC Builder Generated Altera model:\n");
$write("'DE10_Standard_QSYS_sdram_test_component.v', to simulate accesses to SDRAM.\n");
$write("Initial contents are loaded from the file: 'DE10_Standard_QSYS_sdram_test_component.dat'.\n");
end
//Synchronous write when (CODE == 24'h205752 (write))
DE10_Standard_QSYS_sdram_test_component_ram_module DE10_Standard_QSYS_sdram_test_component_ram
.data (rmw_temp),
.q (read_data),
.rdaddress ((CODE == 24'h205752) ? test_addr : read_addr),
.rdclken (1'b1),
.wraddress (test_addr),
.wrclock (clk),
.wren (CODE == 24'h205752)
assign cke = zs_cke;
assign cs_n = zs_cs_n;
assign ras_n = zs_ras_n;
assign cas_n = zs_cas_n;
assign we_n = zs_we_n;
assign dqm = zs_dqm;
assign ba = zs_ba;
assign a = zs_addr;
assign cmd_code = {ras_n, cas_n, we_n};
assign CODE = (&cs_n) ? 24'h494e48 : txt_code;
assign addr_col = a[9 : 0];
assign test_addr = {addr_crb, addr_col};
assign mem_bytes = read_data;
assign rmw_temp[7 : 0] = dqm[0] ? mem_bytes[7 : 0] : zs_dq[7 : 0];
assign rmw_temp[15 : 8] = dqm[1] ? mem_bytes[15 : 8] : zs_dq[15 : 8];
// Handle Input.
always @(posedge clk)
begin
// No Activity of Clock Disabled
if (cke)
begin
// LMR: Get CAS_Latency.
if (CODE == 24'h4c4d52)
latency <= a[6 : 4];
// ACT: Get Row/Bank Address.
if (CODE == 24'h414354)
addr_crb <= {ba[1], a, ba[0]};
rd_valid_pipe[2] <= rd_valid_pipe[1];
rd_valid_pipe[1] <= rd_valid_pipe[0];
rd_valid_pipe[0] <= CODE == 24'h205244;
rd_addr_pipe_2 <= rd_addr_pipe_1;
rd_addr_pipe_1 <= rd_addr_pipe_0;
rd_addr_pipe_0 <= test_addr;
rd_mask_pipe_2 <= rd_mask_pipe_1;
rd_mask_pipe_1 <= rd_mask_pipe_0;
rd_mask_pipe_0 <= dqm;
end
end
assign read_temp[7 : 0] = mask[0] ? 8'bz : read_data[7 : 0];
assign read_temp[15 : 8] = mask[1] ? 8'bz : read_data[15 : 8];
//use index to select which pipeline stage drives addr
assign read_addr = (index == 0)? rd_addr_pipe_0 :
(index == 1)? rd_addr_pipe_1 :
rd_addr_pipe_2;
//use index to select which pipeline stage drives mask
assign read_mask = (index == 0)? rd_mask_pipe_0 :
(index == 1)? rd_mask_pipe_1 :
rd_mask_pipe_2;
//use index to select which pipeline stage drives valid
assign read_valid = (index == 0)? rd_valid_pipe[0] :
(index == 1)? rd_valid_pipe[1] :
rd_valid_pipe[2];
assign index = latency - 1'b1;
assign mask = read_mask;
assign zs_dq = read_valid ? read_temp : {16{1'bz}};
assign txt_code = (cmd_code == 3'h0)? 24'h4c4d52 :
(cmd_code == 3'h1)? 24'h415246 :
(cmd_code == 3'h2)? 24'h505245 :
(cmd_code == 3'h3)? 24'h414354 :
(cmd_code == 3'h4)? 24'h205752 :
(cmd_code == 3'h5)? 24'h205244 :
(cmd_code == 3'h6)? 24'h425354 :
(cmd_code == 3'h7)? 24'h4e4f50 :
24'h424144;
endmodule
However, when I run the simulation I am not getting what I expect from a read request. As far as I can tell, the read data is appearing 1 clock cycle too late.
Any ideas on whether this model is correct or not? Additionally, is there an example testbench that demonstrates a working SDRAM component?
Many thanks
SDRAM on the DE10-Standard board is from the manufacturer ISSI. You can always obtain the simulation models from that particular manufacturer. Check this link https://www.issi.com/WW/PSearch/USPSearch/PSearch_DRAM.aspx#
- Simulation Models can be downloaded from the product pages. Please go to PRODUCTS in the menu above, and click on the type of product for which you would like the model. Then scroll down to the part number of interest, and refer to the model on the right-hand side of that row.
- Simulation Models not listed above may be available upon request
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
Let me know if you have any further concern or consideration.
Thank you.
Sheng
Since there are no further feedback for this thread, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you. Thank you.
