5975 Discussions
Stratix 10 GX Dev Kit OpenCL: aocl diagnose error
gustifix
In my previous post I got the Intel OpenCL BSP for Stratix 10 version 20.2 running on the Stratix 10 GX Dev Kit (part 1SG280HU2F50E2VG). After also adjusting the driver for Linux kernel 6.6, I could run `aocl diagnose`.
Now, I get the following errors about memory containing the wrong data:
BSP Diagnostics
Using Device with name: s10gx : Stratix 10 Reference Platform (acls10_ref0)
Using Device from vendor: Intel(R) Corporation
clGetDeviceInfo CL_DEVICE_GLOBAL_MEM_SIZE = 2147482624
clGetDeviceInfo CL_DEVICE_MAX_MEM_ALLOC_SIZE = 2147482624
Allocated 2147482624 bytes
Actual maximum buffer size = 2147482624 bytes
Writing 2047 MB to global memory ...
Allocated 1073741824 Bytes host buffer for large transfers
Write speed: 5897.15 MB/s [5848.87 -> 5946.23]
Reading and verifying 2047 MB from global memory ...
Verification failure at element 384, expected 180 but read back 10200000138
First failure at address c00
Verification failure at element 385, expected 181 but read back 220100000139
Verification failure at element 386, expected 182 but read back 418c0000013a
Verification failure at element 387, expected 183 but read back 22640000013b
Verification failure at element 388, expected 184 but read back 64010000013c
Verification failure at element 389, expected 185 but read back 6000000013d
Verification failure at element 390, expected 186 but read back 1a020000013e
Verification failure at element 391, expected 187 but read back 20000013f
Verification failure at element 392, expected 188 but read back 60000000148
Verification failure at element 393, expected 189 but read back 1a0200000149
Verification failure at element 394, expected 18a but read back 20000014a
Verification failure at element 395, expected 18b but read back 64010000014b
Verification failure at element 396, expected 18c but read back 22010000014c
Verification failure at element 397, expected 18d but read back 418c0000014d
Verification failure at element 398, expected 18e but read back 22640000014e
Verification failure at element 399, expected 18f but read back 1020000014f
Verification failure at element 400, expected 190 but read back 150
Verification failure at element 401, expected 191 but read back 151
Verification failure at element 402, expected 192 but read back 152
Verification failure at element 403, expected 193 but read back 153
Verification failure at element 404, expected 194 but read back 154
Verification failure at element 405, expected 195 but read back 155
Verification failure at element 406, expected 196 but read back 156
Verification failure at element 407, expected 197 but read back 157
Verification failure at element 408, expected 198 but read back 60000000158
Verification failure at element 409, expected 199 but read back 1a0200000159
Verification failure at element 410, expected 19a but read back 20000015a
Verification failure at element 411, expected 19b but read back 64010000015b
Verification failure at element 412, expected 19c but read back 22010000015c
Verification failure at element 413, expected 19d but read back 418c0000015d
Verification failure at element 414, expected 19e but read back 22640000015e
Verification failure at element 415, expected 19f but read back 1020000015f
Suppressing error output, counting # of errors ...
Read speed: 6394.52 MB/s [6392.18 -> 6396.86]
Failed write/readback test with 243050504 errors
Error: Global memory test failed
Error code: 0
I did fairly small adjustments to the BSP (change device part number, slightly adjust PLACE_REGION and ROUTE_REGION in base.qsf).
For the driver, I did the following adjustments:
+++ b/./aclpci.c
@@ -55,7 +55,6 @@
 MODULE_AUTHOR  ("Dmitry Denisenko");
 MODULE_DESCRIPTION ("Driver for Intel(R) OpenCL Acceleration Boards");
-MODULE_SUPPORTED_DEVICE ("Intel(R) OpenCL Boards");
 MODULE_LICENSE("GPL");
@@ -409,8 +408,8 @@ int init_irq (struct pci_dev *dev, void *dev_id) {
   if(pci_enable_msi(dev) != 0){
     ACL_DEBUG (KERN_WARNING "Could not enable MSI");
-  if (!pci_set_dma_mask(dev, DMA_BIT_MASK(64))) {
-    pci_set_consistent_dma_mask(dev, DMA_BIT_MASK(64));
+  if (!dma_set_mask(&dev->dev, DMA_BIT_MASK(64))) {
+    dma_set_coherent_mask(&dev->dev, DMA_BIT_MASK(64));
     ACL_DEBUG (KERN_WARNING "using a 64-bit irq mask\n");
   } else {
     ACL_DEBUG (KERN_WARNING "unable to use 64-bit irq mask\n");
@@ -813,7 +812,7 @@ static int __init aclpci_init(void) {
   aclpci_major = MAJOR(dev);
-  aclpci_class = class_create(THIS_MODULE, DRIVER_NAME);
+  aclpci_class = class_create(DRIVER_NAME);
   if (IS_ERR(aclpci_class)) {
     printk(KERN_ERR "aclpci: can't create class\n");
     goto err_unchr;
+++ b/./aclpci_cmd.c
@@ -294,12 +294,12 @@ static int __aclpci_get_user_pages(struct task_struct *target_task, unsigned lon
        for (got = 0; got < num_pages; got += ret) {
 #if LINUX_VERSION_CODE >= KERNEL_VERSION(4, 10, 0)
-   ret = get_user_pages_remote(target_task, target_task->mm,
+   ret = get_user_pages_remote(target_task->mm,
                                     start_page + got * PAGE_SIZE,
                                     num_pages - got,
                                     FOLL_WRITE|FOLL_FORCE,
                                     p + got,
-                                    vma, NULL);
+                                    NULL);
 #elif LINUX_VERSION_CODE >= KERNEL_VERSION(4, 9, 0)
@@ -350,9 +350,9 @@ int aclpci_get_user_pages(struct task_struct *target_task, unsigned long start_p
        if( target_task->mm == NULL) {
                ret = -EIO;
        } else {
-               down_write(&target_task->mm->mmap_sem);
+               down_write(&target_task->mm->mmap_lock);
                ret = __aclpci_get_user_pages(target_task, start_page, num_pages, p, NULL);
-               up_write(&target_task->mm->mmap_sem);
+               up_write(&target_task->mm->mmap_lock);
        return ret;
@@ -361,13 +361,13 @@ int aclpci_get_user_pages(struct task_struct *target_task, unsigned long start_p
 void aclpci_release_user_pages(struct task_struct *target_task, struct page **p, size_t num_pages)
        if( target_task->mm != NULL) {
                __aclpci_release_user_pages(p, num_pages, 1);
                target_task->mm->locked_vm -= num_pages;
+++ b/./aclpci_dma.c
@@ -355,7 +355,7 @@ int lock_dma_buffer (struct aclpci_dev *aclpci, void *addr, ssize_t len, struct
   dma->ptr = addr;
   dma->len = len;
-  dma->dir = d->m_read ? PCI_DMA_FROMDEVICE : PCI_DMA_TODEVICE;
+  dma->dir = d->m_read ? DMA_FROM_DEVICE : DMA_TO_DEVICE;
   /* num_pages that [addr, addr+len] map to. */
   start_page = (ssize_t)addr >> PAGE_SHIFT;
   end_page = ((ssize_t)addr + len - 1) >> PAGE_SHIFT;
@@ -393,7 +393,7 @@ int lock_dma_buffer (struct aclpci_dev *aclpci, void *addr, ssize_t len, struct
     // ACL_DEBUG (KERN_DEBUG "p[%d] = 0x%p", i, cur);
     if (cur != NULL) {
       // ACL_DEBUG (KERN_DEBUG "  phys_addr = 0x%llx", page_to_phys(cur));
-      phys = pci_map_page (d->m_pci_dev, cur, 0, PAGE_SIZE, dma->dir);
+      phys = dma_map_page (&d->m_pci_dev->dev, cur, 0, PAGE_SIZE, dma->dir);
       if (phys == 0) {
         ACL_DEBUG (KERN_DEBUG "  Couldn't pci_map_page!");
         return -EFAULT;
@@ -445,7 +445,7 @@ void unlock_dma_buffer (struct aclpci_dev *aclpci, struct dma_t *dma) {
     // ACL_DEBUG (KERN_DEBUG "p[%d] = %p", i, cur);
     if (cur != NULL) {
       dma_addr_t phys = dma->dma_addrs[i];
-      pci_unmap_page (d->m_pci_dev, phys, PAGE_SIZE, dma->dir);
+      dma_unmap_page (&d->m_pci_dev->dev, phys, PAGE_SIZE, dma->dir);
   #endif
@@ -1047,7 +1047,7 @@ int hostch_buffer_lock(struct aclpci_dev *aclpci, void *addr, ssize_t len, struc
   dma->ptr = addr;
   dma->len = len;
-  dma->dir = direction ? PCI_DMA_FROMDEVICE : PCI_DMA_TODEVICE;
+  dma->dir = direction ? DMA_FROM_DEVICE : DMA_TO_DEVICE;
+++ b/./aclpci_fileio.c
@@ -150,7 +150,7 @@ int aclpci_open(struct inode *inode, struct file *file) {
   /* pointer to containing data structure of the character device inode */
   aclpci = container_of(inode->i_cdev, struct aclpci_dev, cdev);
-  spin_lock(&aclpci->lock);
+  // spin_lock(&aclpci->lock);
   if (aclpci->num_handles_open) {
       printk("Device already in use\n");
       result = -EBUSY;
@@ -215,7 +215,7 @@ int aclpci_open(struct inode *inode, struct file *file) {
   result = 0;
 done:
-  spin_unlock(&aclpci->lock);
+  // spin_unlock(&aclpci->lock);
   up (&aclpci->sem);
   return result;
 Most modifications were just function names or parameters that changed. Removing the locking in the last file was my solution to the driver crashing with the message `BUG: scheduling while atomic
` in dmesg. As far as I understood, removing the locking there would not be a problem as long as there aren't multiple processes calling `aclpci_open()` at the same time.
I'd appreciate some feedback where you think the problem with aocl diagnose could come from.
Thanks and best regards!
Felix
aikeu
Hi Felix,
Can check if you have any problem running the FPGA board initialization?
https://www.intel.com/content/www/us/en/docs/oneapi/programming-guide/2023-0/fpga-board-initialization.html
Aik Eu
gustifix
Hi Aik Eu,
The command "aocl initialize acl0 s10gx" reports "Program succeed." but "aocl diagnose acl0" still gives the errors. However, the first verification failure is not always at the same address and the total number of errors is also different.
Best regards
Felix
aikeu
Hi gustifix,
Sorry for the late respond, opencl is already eol for your referance on the links below:
https://community.intel.com/t5/OpenCL-for-CPU/OpenCL-SDK-EOL-What-to-do-with-existing-OpenCL-code/td-p/1375349
https://www.intel.com/content/www/us/en/developer/articles/tool/tools-for-opencl-applications.html
You will need to upgrade opencl to sycl as
https://www.intel.com/content/www/us/en/docs/oneapi/programming-guide/2024-0/migrating-from-opencl-code-to-sycl.html
I am checking if there is any help with the errors that you are facing and will let you know if there is any information which may help.
Aik Eu
gustifix
Hi @aikeu,
Thanks! Do you know if we can use oneAPI with the Stratix 10 GX Dev Kit? The Intel FPGA oneAPI website doesn't list a board support package for it under "Choose an FPGA platform" but the DPC++ system requirements page lists the Stratix 10 as supported FPGA device. Can you only use oneAPI with an FPGA using a board support package?
Best regards
Felix
aikeu
Hi gustifix,
Strarix 10 GX is a supported device in the oneAPI compiler.
Aik Eu
gustifix
Hi @aikeu,
Do we also need a oneAPI specific Board Support Package for the card to run OpenCL code? The oneAPI website doesn't list a BSP for the Stratix 10 GX and the documentation mentions "To compile an executable that can run on an FPGA board, install a Board Support Package (BSP) that allows targeting compiles to that board. Intel does not ship BSPs with oneAPI. You must download and install BSPs from a third-party vendor.". Is there a oneAPI BSP for our card available or can we use the existing OpenCL BSP for oneAPI?
Thanks again and best regards,
Felix
aikeu
Hi gustifix,
oneAPI uses OpenCL under the hood, so ideally the flow should work by simply targeting the BSP for compile in the oneAPI copmiler. oneAPI compiler has a range of supported Quartus versions. Ensure the BSP version is in the range.
https://www.intel.com/content/www/us/en/developer/articles/system-requirements/intel-oneapi-dpcpp-system-requirements.html
To target the BSP for compiler, use the -Xstarget=<path-to-bsp:board-variant> in the command.
https://www.intel.com/content/www/us/en/docs/oneapi-fpga-add-on/developer-guide/2024-1/fpga-compilation-flags.html
Once compilation is done, the BSP must be installed (aocl install) and then the user can try running the application.
Aik Eu
aikeu
Hi gustifix,
I will close the thread if no further question.
Aik Eu
