6472 Discussions
Stratix 10 HPS Ethernet ping issue - Linux kernel
Selva_Rani
I am working with the Stratix 10 HPS Ethernet, and I am encountering an issue related to the GMAC interfaces in the Linux kernel. The following link is used to build eMMC image: "https://www.rocketboards.org/foswiki/Projects/Stratix10SoCWithEMMCStorageOnHPS".
The first GMAC is functioning as expected—its link is up, and I am able to ping successfully. However, with the second GMAC, although the link is up, pinging is failing.
In the DTS, the GMAC 1 entry has been added, and the eMMC image has been generated. Despite the link is up, I cannot get the second GMAC to ping.
Jeet14
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
Jeet14
I found the same case opened from the IPS Case.
I will proceed to close this case and all communication will be on the IPS case.
Tiwari
