6477 Discussions
The issue encountered when programming the POF file into MAX10
xingyunzhidi
After powering on my FPGA development board, the power status LED did not light up, so I checked it and found that the issue was with the MAX10 chip. I then planned to reprogram the MAX10 using the max10_bmc.pof file located in the factory_recovery/max10_recovery directory in BTS. However, during the programming process, Quartus reported the following error: Error(209015): Can't configure device. Expected JTAG ID code 0x031050DD for device 1, but found JTAG ID code 0x020D10DD. Make sure the location of the target device on the circuit board matches the device's location in the device chain in the Chain Description File (.cdf).error.jpg
WZ2
May I ask which development board you are using?
Some boards require specific switch settings.
Also, could you please confirm whether the board matches the installation package you downloaded?
