6462 Discussions
Which is the low power,low clb block fpga recommended for an on the fly video processing.
GDcru
JohnT_Intel
May I know what is the requirement such as frame per second for your video processing?
GDcru
JohnT_Intel
  1. What is the interface that you planned to used?
  2. What is the video resolution that you planned to used?
GDcru
the interface to be used is mipi and resolution of 1080p at 60fps
JohnT_Intel
May I know what type of video processing are you planning to performed? Do you need any other interface other than MIPI which is supposed to be for Camera connection.
GDcru
The video processing planned yet are some zooming,cropping etc..currently a single camera connection is in suggestion.1080p at 60 fps.if an fpga or an soc can do it,its good
JohnT_Intel
Then I would recommend you to use Cyclone V GX or Cyclone V SOC. You can get more information related to Cyclone V from https://www.intel.com/content/www/us/en/products/programmable/fpga/cyclone-v.html.
