5949 Discussions
Why is the reslut of 18.1 standard and pro for migration device difference?
PYu2
Partner
when I use Quartus prime standard edition 18.1 to make migration for 10AX048H4F34I3SG & 10AX027H4F34I3SG, the reslut is difference 18.1Pro. I also use 19.2 Pro ,the result is the same with 18.1Pro. I want to know that is bug?
KhaiChein_Y_Intel
This post is the same as https://forums.intel.com/s/question/0D50P00004bTO83. May I know which post you want to use for communication?
I compared the pin file for standard181 and pro191. The pin location are the same for both version. May I know what is the differences ? May I know what is pcg you are referring to?
KhaiY
KhaiChein_Y_Intel
May I know if you have any updates?
KhaiY
