5984 Discussions
bring up agilex failed, hang at "pte not found"
shirley_azi
I have a custom board of AGFB027R25AR0. I want to bring it up, now I follow the article below and encounter the following problems:
#keywords. tags
agilex, fpga, u-boot, spl
1. `Env setup`
export CROSS_COMPILE=aarch64-none-linux-gnu- KCFLAGS=-DDEBUG
export ARCH=arm
export TOP_FOLDER=`pwd`
2. `Build Arm Trusted Firmware`
cd $TOP_FOLDER
rm -rf arm-trusted-firmware
cd arm-trusted-firmware
# comment out next line to use the latest ATF branch
git checkout -b socfpga_v2.10.0 origin/socfpga_v2.10.0
make bl31 PLAT=agilex DEPRECATED=1
cd ..
3. `Build U-Boot`
rm -rf u-boot-socfpga
cd u-boot-socfpga
# comment out next line to use the latest default branch
git checkout -b socfpga_v2022.10 -t origin/socfpga_v2022.10
# enable dwarf4 debug info, for compatibility with arm ds
sed -i 's/PLATFORM_CPPFLAGS += -D__ARM__/PLATFORM_CPPFLAGS += -D__ARM__ -gdwarf-4/g' arch/arm/config.mk
# use 'Image' for kernel image instead of 'kernel.itb'
sed -i 's/kernel\.itb/Image/g' include/configs/socfpga_soc64_common.h
# only boot from SD, do not try QSPI and NAND
sed -i 's/u-boot,spl-boot-order.*/u-boot\,spl-boot-order = \&flash0;/g' arch/arm/dts/socfpga_agilex_socdk-u-boot.dtsi
# disable NAND in the device tree
sed -i '/&nand {/!b;n;c\\tstatus = "disabled";' arch/arm/dts/socfpga_agilex_socdk-u-boot.dtsi
# remove the NAND configuration from device tree
sed -i '/images/,/binman/{/binman/!d}' arch/arm/dts/socfpga_agilex_socdk-u-boot.dtsi
# link to atf
ln -s $TOP_FOLDER/arm-trusted-firmware/build/agilex/release/bl31.bin .
# Create configuration custom file.
cat << EOF > config-fragment-agilex
# - Disable NAND/UBI related settings from defconfig.
CONFIG_NAND_BOOT=n
CONFIG_SPL_NAND_SUPPORT=n
CONFIG_CMD_NAND_TRIMFFS=n
CONFIG_CMD_NAND_LOCK_UNLOCK=n
CONFIG_NAND_DENALI_DT=n
CONFIG_SYS_NAND_U_BOOT_LOCATIONS=n
CONFIG_SPL_NAND_FRAMEWORK=n
CONFIG_CMD_NAND=n
CONFIG_MTD_RAW_NAND=n
CONFIG_CMD_UBI=n
CONFIG_CMD_UBIFS=n
CONFIG_MTD_UBI=n
CONFIG_ENV_IS_IN_UBI=n
CONFIG_UBI_SILENCE_MSG=n
CONFIG_UBIFS_SILENCE_MSG=n
# - Disable distroboot and use specific boot command.
CONFIG_DISTRO_DEFAULTS=n
CONFIG_HUSH_PARSER=y
CONFIG_SYS_PROMPT_HUSH_PS2="> "
# Enable more QSPI flash manufacturers
CONFIG_SPI_FLASH_MACRONIX=y
CONFIG_SPI_FLASH_GIGADEVICE=y
CONFIG_SPI_FLASH_WINBOND=y
CONFIG_SPI_FLASH_ISSI=y
EOF
# change ddr bank number to 1
vi configs/socfpga_agilex_defconfig
CONFIG_NR_DRAM_BANKS 1
# change dtsi memory node to 1GB
vi arch/arm/dts/socfpga_agilex_socdk-u-boot.dtsi
        memory {
               /* 1GB */
               reg = <0 0x00000000 0 0x40000000>;
# build U-Boot
make clean && make mrproper
make socfpga_agilex_defconfig
# Use created custom configuration file to merge with the default configuration obtained in .config file.
./scripts/kconfig/merge_config.sh -O ./ ./.config ./config-fragment-agilex
make -j 64
cd ..
#package and program
quartus_pfg -c intel_prj.sof output_prj.sof -o hps_path=u-boot-spl-dtb.hex
quartus_pgm -c 1 -m jtag -o "p;output_prj.sof@2"
#terminal console output
"pte not found", and then hang...
4. `Version Info`:
- Quartus: 22.04
- u-boot: socfpga_v2022.10
- ATF: socfpga_v2.10.0
- Board: boot from QSPI(256M GIGADEVICE), no emmc, 1GB SDRAM(I don't know why it can't read 3GB SDRAM??? If I change it to 3GB in dtb, I will failed in sdram_mmr_init_full->`gd->ram_size > hw_size`->‘DDR: Error: DRAM size from device tree is greater than hardware size.’)
- Memory Layout: follow the attached.
shirley_azi
Can someone help me?
JingyangTeh
Hi Shirley
Is it possible that you share the full terminal logs?
This is to see which stage the board have already booted.
Jingyang, Teh
shirley_azi
Of course, the complete log is in the attachment pack above named "uboot output info.txt", it stucks at the stage of u-boot SPL...
This is the result that I packaged the logic bitstream and uboot-spl.hex into a new sof and burning the board in.
And I noticed the DRAM size is different with the demo project, then I refer to this post to make modifications. But it still fails to boot...
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/946062/processor-sdk-dra8x-tda4x-u-boot-error-pte-not-found-resetting
JingyangTeh
Hi
Could you try changing the parameter of the "CONFIG_NR_DRAM_BANKS" back to the default and try again?
CONFIG_NR_DRAM_BANKS=2
Jingyang, Teh
JingyangTeh
Hi
Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 4 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
shirley_azi
The problem is solved, it is the SDRAM clock configuration problem of the fpga, just refer to the manual configuration and it will work normally.
