clock gate conversion issue
ymiler
Hi
My  FPGA desgin is prototype which use for ASIC RTL ,
Part of my desgin includes clock gate which choose 1 clock from several synchronized clocks (generated from same source clock )
Additionally, the clock gate instance includes a solution for glitch clock by enabling/disabling the clock at the falling edge (using a NOT logic element) :
The current synthesis & mappin are performed  by Synplify Premier tool and P & R by Quartus ( version 22.3 )
The clock gate solution is :
Same clock for all the FF's enabling the selection of the appropriate rate via a multiplexer (mux).
Regarding the glitch mux soultion which has 'not' logic element  - Synplify Premier create a new output clock from the PLL referred to as <clock_name>_inv_proxy and create relevant constraint for Quartus - all these worked fine without any timing issues  ,
Now I'd like to do all the process in Quartus ( for same design )
Quartus doesn't automatically generate a new inverted clock from the PLL. Instead, it retains the 'not' logic element."
this status cause to setup vilolation since the clock routing is as other logic elements routing
please advice
sstrell
Can't you just invert the clock in the PLL output settings?
Side note: none of what you mentioned is recommended for FPGA design (latches and gated clocks), though you do mention this is for prototyping an ASIC design.
ymiler
There are 2 paths for same output source clock
1) posedge edge ( FF's )
2) negedge edge ( for glitchless mux code )
If I simply invert the PLL clock, I can change the functional code
Synplify Premier didn't change the functionality by adding 1 more output clock from PLL (  specific to glitch mux code ) and removing  the 'not' gate in the "glitch mux" code
ShengN_Intel
How about adding clock inversion primitive from PLL to glitch mux which has 'not' logic element?
Sheng
ymiler
This is an option, but I prefer to do not change the code manually.
The preferred option is for the tool to be able to solve the problem on its own
ShengN_Intel
Probably this is something to be enhanced. Could you provide a minimal test case for duplicating the limitation?
Sheng
ymiler
I'll try to generate minimal test case
ShengN_Intel
Sure, will wait for the minimal test case.
ymiler
Hi
For the beginning, I create a test case with minimal design:
PLL - > clock gate -> counter (with no inverse clock)
I have the flag :
set_global_assignment -name SYNTH_GATED_CLOCK_CONVERSION ON
Why Quartus did not convert the clock gate?
ShengN_Intel
You need this further assignment set_global_assignment -name SYNTH_GATED_CLOCK_CONVERSION_BASE_CLOCK ON -entity bonsai_top
Report screenshot:
ymiler
Indeed , It's working !!
Now , I added 1 more clock gate .
Meaning the output clock of CG A is connecting to CG B input clock
( attached new archive file )
I have same case in my prototype RTL release
In this case , Quartus didn't convert the clock gates
please advice
ShengN_Intel
When you cascade CG A and CG B, it forms a gated clock tree. Latch (CPEN) is an unsupported gate in the gated clock tree. May be can use flip-flop or combinational logic for the clock gating cascading.
Sheng
ShengN_Intel
May I know do you have any further update or concern?
Sheng
ymiler
Just ask to support CG cascading case in the next release
