clock gated conversion
ymiler
I'm running Quartus 22.3 building for an S10 FPGA.
Since my FPGA is prototype, the project includes several clock gated
to solve it I added the following command to the QSF :
set_global_assignment -name SYNTH_GATED_CLOCK_CONVERSION ON -
(replace all the clock gated to clock enable)
After the synthesis and P & R  the *.syn.rpt file show list of gated clocks which found and converted to use as clock enable
but at least 1 clock gated doesn't convert and I get hold violation on this path.
I expected to see any information about this  clock gated on the report like as list of unconverted gated clocks(and reason why its not converted) , but there is no list at all in this file .
please advice
sstrell
It would help to see some code and understand why you have so many gated clocks to begin with.  It would be much better to use clock enables instead of gated clocks.
ymiler
Hi
Original code is ASIC RTL who use clock gate to decrease power supply.
Here the clock gated code:
// Gated Clock Latch
module gcw__ckltchand (
TE,
E,
CP,
Q
input TE;
input E;
input CP;
output Q;
wire EN_TE;
reg CPEN;
or or1 (EN_TE,E,TE);
always @(EN_TE or CP)
if(~CP) CPEN <= EN_TE;
and an1 (Q,CPEN,CP);
endmodule //gcw__ckltchand
RichardTanSY_Intel
By adding the top.v file with attached code. The tool able to recognize the gated clock and converted to use clock enables.
Info(19019): Convert gated clock gcw__ckltchand_1|Q
module top (
input i_rst_n,
input i_en,
input i_clk,
input i_data,
output reg o_data
wire gclk;
gcw__ckltchand gcw__ckltchand_1 (
.CP(i_clk),
.E(i_en),
.TE(),
.Q(gclk)
always @(posedge gclk or negedge i_rst_n) begin
if (!i_rst_n) begin
o_data <= 1'b0;
end else begin
o_data <= i_data;
end
end
endmodule
Perhaps you could check your design hierarchy to see what might be going wrong.
You could also share a simple testcase .qar file (Project > Archive Project) that you expect the tool to convert the gated clock but it does not.
Richard Tan
RichardTanSY_Intel
Dropping a note to ask if my last reply was helpful to you?
Do you need any further assistance from my side?
Richard Tan
RichardTanSY_Intel
We noticed that we haven't received a response from you regarding the latest previous question/reply/answer, and will now transitioning your inquiry to our community support. We apologize for any inconvenience this may cause and we appreciate your understanding.
If you have any further questions or concerns, please don't hesitate to let us know.
Thank you for reaching out to us!
Richard Tan
