6473 Discussions
missing source code (increment_leds.c ) on Using Linux on DE-series Boards
SA2205
the PDF "Using Linux on DE-series Boards"  does not come with the source code  increment_leds.c on page 26 last paragraph. Which is needed for the rest of the appendixes.
Is there a way to get a hold of this file?
Thanks in advance.
https://ftp.intel.com/Public/Pub/fpgaup/pub/Teaching_Materials/current/Tutorials/Linux_On_DE_Series_Boards.pdf
Hazlina_R_Intel
Hi @Lawrence_L_Intel Can you please have someone looked into this?
Lawrence_L_Intel
The increment_leds.c file is on the SD card under ~/tutorial_files/increment_leds (~ = /home/root). Since you are using code blocks off of the SD card everything is available there. Thanks
